象山县西周明源住宅小区设计
【摘 要】:本专业设计是住宅楼设计.有建筑设计和结构设计施工组织设计三部分组成。结构设计是本专业设计的重点,其主要有结构设计说明书,结构施工图两部分组成.结构设计主要是竖向荷载作用下的框架计算和水平荷载作用下的地震作用计算,内力组合,梁柱配筋,楼梯计算,基础计算.竖向荷载作用下的框架计算.本设计取一榀框架,九层,三跨.采用弯矩分配法逐层求得.水平抗震计算:主要由D值法求得.求出上述内力后,即可进行内力组合.然后进行梁柱的配筋.最后进行基础设计。
对本工程的施工组织设计,使建筑施工活动协调有序,能高效低耗地完成建设项目的施工任务。达到缩短工期、降低成本和争创优质的效果。
【关键词】:建筑设计 结构设计 土木毕设网
Design of Residential Area in Xi Zhou Mingyuan District, Xiangshan CountyYe
【Abstract】:This professional design is residential building design. There are three parts of architectural design and structural design construction organization design.Structural design is the focus of the professional design, which mainly consists of structural design specifications, structural construction drawings two parts. The structural design is mainly frame calculation under vertical load and seismic action calculation under horizontal load, internal force combination, Liang Zhu reinforcement, staircase calculation, foundation calculation. frame calculation under vertical load. This design takes a frame, nine layers, three spans. The bending moment distribution method is used to obtain layer by layer. Horizontal seismic calculation: mainly obtained by D value method. After calculating the above internal forces, the internal forces can be combined. Then the reinforcement of Liang Zhu is carried out. Finally, the basic design is carried out.
The construction organization design of the project, so that the construction activities are coordinated and orderly, and the construction tasks of the construction project can be completed efficiently and cheaply. achieve the effect of shortening the time limit, reducing the cost and striving for quality.
【key words】: Architectural design Structural design
