以下是土木毕设网小编为大家搜集整理的土木毕设摘要模板,供大家参考和借鉴!
根据教学楼设计规范和其它相关标准,以及设计要求和提供的地质资料,设计该框架结构教学楼。按照先建筑后结构,先整体布局后局部节点设计步骤设计。主要内容包括:设计资料、建筑设计总说明、建筑的平面、立面、剖面图设计说明,以及其它部分的设计说明;结构平面布置及计算简图确定、荷载计算、内力计算、内力组合、主梁截面设计和配筋计算、框架柱截面设计和配筋计算、次梁截面设计配筋计算、楼板和屋面设计、楼梯设计,基础设计等。其中附有风荷载作用下的框架弯矩、剪力和轴力图;纵向和横向地震荷载作用下的框架弯矩、剪力和轴力图;恒荷载和活荷载作用下的框架弯矩、剪力和轴力图以及梁柱的内力组合表。
According:to building design specifications and other relevant standards and design requirements and provide geological data,the design of the framework of the classroom building.After the first building in accordance with the structure and layout of the overall after the first local node design steps design.Main contents include:design,architectural design of the total shows that the construction of the plane,Facade,profile design specifications,,and other parts of the design;structural layout and schematic calculation of identification,load,stress,the combination of internal forces,Main beam reinforcement design and calculation,frame-section design and reinforcement,meeting beam reinforcement design,floor and roof design,stair design,infrastructure design.Enclosing wind load under the framework moment,shear and axial bid;vertical and horizontal seismic loads under the framework of the moment,shear and axial bid;Constant load and live load under the framework moment,shear and axial trying to intemal forces and the combination of beam-column table.
Key Words:frame,Gravity load charecter value,cast-in-place reinforced concrete structure internal force make up,curved square amplitude modulation.
