本毕业设计题目是教学楼设计,该办公楼的总建筑面积大约是5000平方米,共五层,建筑高度为18.9米。本建筑采用钢筋混凝土全现浇框架结构体系。基础采用独立基础。
本设计说明书中包括设计说明和设计计算书。其中计算书部分选取品框架进行手算,配合电算进行校核。
设计说明的主要内容分为建筑说明和结构说明。建筑注重平面、立面和剖面的统一结合,以及和结构部分的联系,还有主要构件的施工做法。结构部分包括构件尺寸的初步确定、框架的计算简图、荷载计算、框架横向侧移计算、框架在水平及竖向荷载作用下的内力计算分析和计算、内力组合、截面设计及地基基础的设计等。
图纸包括二十张,其中建筑图九张,结构图十一张。
其中就行一品框架计算时,可用电算进行校核。电算步骤为:先用PMCAD软件进行结构平面布置,检查平面数据,输入次梁楼板,输入荷载数据,形成PK文件,画结构平面图,然后使用PK进行框架计算;最后用相关软件进行框架的空间结构计算,输出框架梁柱配筋梁,柱配筋图及内力计算结果。
关键词:毕业设计,框架结构,独立基础,内力组合
abstract
The title of this graduation project is the design of the teaching building of Xuchang health vocational secondary vocational school.The total construction area of the office building is about 5000 square meters,a total of five floors,and the building height is 18.9 meters.The building adopts reinforced concrete full cast-in-situ frame structure system.The foundation adopts independent foundation.
This design specification includes design description and design calculation sheet.In the calculation sheet,the product frame is selected for manual calculation and checked with the help of computer calculation.
The main contents of the design description are divided into architectural description and structural description.The building pays attention to the unified combination of plane,facade and section,as well as the connection with structural parts,as well as the construction methods of main components.The structural part includes the preliminary determination of component size,calculation diagram of frame,load calculation,lateral displacement calculation of frame,calculation,analysis and calculation of internal force of frame under horizontal and vertical load,internal force combination,section design and foundation design,etc.
There are 20 drawings,including 9 architectural drawings and 11 structural drawings.
Among them,in the calculation of line one product frame,it can be checked by computer.The computer calculation steps are as follows:firstly,use PMCAD software to carry out structural plane layout,check plane data,input secondary beam floor,input load data,form PK file,draw structural plan,and then use PK for frame calculation;Finally,the spatial structure of the frame is calculated with relevant software,and the frame beam column reinforcement diagram,column reinforcement diagram and internal force calculation results are output.
Key words:graduation project,frame structure,independent foundation,internal force combination
