资料简介: 摘 要
公路施工组织设计就是为了认真贯彻国家现行技术经济政策和法令,根据公路施工的特点,将整个工程项目分解为各单项工程,将各单项工程分解为单位工程,将单位工程分解为各分部工程,将分部工程分解为各项工程进一步分解为各道工序。施工组织设计就是把这许许多多道工序用一定的技术作业链连起来,合理确定各技术作业链之间的关系,即确定各道工序在什么时间、按什么顺序、使什么材料、安排什么人员、选择什么施工设备和机具设备来完成。最终使整个工程项目以最低消耗、最短周期、最优质量得以实现,达到最佳技术经济效果。
本施工组织设计任务为青红公路鲁冀界至邯郸段高速公路第六合同段,其路线走向、建设规模、技术标准等均按初步设计批复意见执行,全线采用高速公路标准建设,设计速度为120km/h,双向4车道,路基宽28米,桥涵设计的汽车荷载等级为公路I级,路面结构采用沥青路面。
关键词:施工组织设计、技术标准、施工工序、沥青路面。
The organization design of highway construction is to carry through the national current technique economic policy and regulation,according to the characteristics of the highway construction, construction organization the design takes engineering item, single-item engineering or the unit engineerings as the object to draw up. While draw up, want to resolve the whole engineering item as each single-item engineering, resolve each single-item engineering as the unit engineering, resolve the unit engineering as each distribute the engineering, cent an engineering resolves to further resolve for the each work preface for various engineerings. The construction organization design is to allow many several works to this to make appointment to post the certain technique homework chain to connect, relation between reasonable certain each technique homework chain, then make sure the each work preface at when, press what in proper order, make what material, arrange what personnel, choose what the construction equipments and the machine tool equipmentses to complete. End make the whole engineering item can carry out with the lowest depletion, the most short period, superior quantity, attain the economic result of the best technique.
The mission of this construction organization designs is to accomplish the sixth contract segment that is from the QingHong highway boundary of HeBei ang ShanDong to the superhighway of HanDan,it is its route alignment, construction of the scale, the technique standard...etc. that all press the first step design to criticize and reply the opinion performance, the whole line adopts the superhighway standard construction, the design speed is 120 km/h, the 4 driveways of the double ways, the 28 meters of the roadbed breadth, the automobile lotus that the bridge design carries the grade as highway Np.1.The raod surface is bituminous pavement.
Key words: Construction organization designs 、Technology standard 、Contruction working produce 、 Bituminous pavement。
