以下就是土木毕设网为大家精心整理的教学楼毕业设计摘要范文。供大家学习。
根据教学楼设计规范和其它相关标准,以及设计要求和提供的地质资料,设计该框架结构教学楼。按照先建筑后结构,先整体布局后局部节点设计步骤设计。主要内容包括:设计资料、建筑设计总说明、建筑的平面、立面、剖面图设计说明,以及其它部分的设计说明;结构平面布置及计算简图确定、荷载计算、内力计算、内力组合、主梁截面设计和配筋计算、框架柱截面设计和配筋计算、次梁截面设计配筋计算、楼板和屋面设计、楼梯设计,基础设计等。其中附有风荷载作用下的框架弯矩、剪力和轴力图;纵向和横向地震荷载作用下的框架弯矩、剪力和轴力图;恒荷载和活荷载作用下的框架弯矩、剪力和轴力图以及梁柱的内力组合表。
关键词:框架;现浇钢筋混凝土结构;内力组合。
Summary
The frame structure teaching building is designed according to the teaching building design specification and other relevant standards,as well as the design requirements and geological data provided.It is designed according to the steps of building before structure,overall layout before local node design.The main contents include:design data,general description of architectural design,design description of plan,elevation and profile of the building,and design description of other parts;Structural plane layout and calculation diagram determination,load calculation,internal force calculation,internal force combination,main beam section design and reinforcement calculation,frame column section design and reinforcement calculation,secondary beam section design and reinforcement calculation,floor and roof design,stair design,foundation design,etc.The frame bending moment,shear force and axial diagram under wind load are attached;Bending moment,shear force and axial diagram of the frame under longitudinal and transverse seismic loads;The bending moment,shear force and axial diagram of the frame under dead load and live load,as well as the internal force combination table of beams and columns.
Keywords:framework;Cast in situ reinforced concrete structure;Internal force combination.
