摘要:本工程为一底层商用,楼上办公的综合楼,属都江堰市灾后重建项目。采用框架结构设计,八度设防。结构层数主体三层,局部四层。
本设计按国家最新规范、标准执行。建筑上集现代办公建筑与川西民居风格为一体,并结合都江堰旅游城市的现实状况进行设计,满足使用功能,并综合考虑消防、无障碍设计、保温节能等;结构采取PKPM软件电算,并选取一榀典型框架手算复核,竖向荷载作用力下框架内力计算采用弯矩分配法,水平荷载作用力下框架内力计算采用D值法,水平地震力作用下框架内力计算采用底部剪力法,力求稳固,安全。达到经济、适用、美观的目的。
关键词:建筑;结构;荷载;内力
ABSTRACT :This project is a ground floor commercial, upper floor office complex building, is a post-disaster reconstruction projects in Dujiangyan City. Frame design with eight minimum security. Three floors of the main structure, local four.
The design according to the latest national norms, standards implementation. Building, part of modern office building with Chuanximinju style as a whole, combined with the reality of the city of Dujiangyan Tourism designed to meet the use function, and considering the fire, barrier-free design, insulation and energy saving; structure to PKPM Software Computer, and select the framework of a typical hand-counted Pin review, under the framework of the vertical load force by moment distribution method for calculating internal forces, internal force under horizontal load force calculated using D value method, the horizontal earthquake force calculate the frame with the bottom of the shear method, strive to secure and safe. To achieve economic, apply, beauty purposes.
KEY WORDS: building;structure;load;internal force
都江堰3层商办楼建筑结构设计计算书.pdf
(1.58 MB, 下载次数: 21)
满意就快下载吧,纯word格式 |
