资料简介: 中文摘要 [摘要]:本次设计的任务是一级公路NO.5段中的K12+000~K14+516.257标段,经过地区主要为山岭微丘区,全长2516.257m ,设计时速为80km/h .路面宽15.0米,路基宽25.50米,包括中间带宽3.0米,路面两侧硬路肩宽3.0米和土路肩宽0.75米。面层采用水泥混凝土,基层为水泥稳定粒料,垫层为18cm级配碎(砾)石材料。主要完成的设计包括:确定公路等级、选择路线的线形、平曲线要素计算、绘制路线纵断面图、竖曲线要素计算、绘制路线典型横断面图、土石方调配、路线超高计算、设计路面结构、路面防护工程设计、路基排水设计、工程预算和施工组织设计,同时设计涵洞共6座,其中暗板涵1座,圆管涵5座。
[关键字]:平曲线,竖曲线,排水,路基,水泥混凝土路面,涵洞
[Abstract]:The design of the task is to guangxi qinzhou chung road. 5 left level of K12 +.000 ~ K14 + 516.257 section, mainly through the area for the high mountains, 2516.257 micro area, design for 80km per m/h j, cheiloschisis or palatoschisis meters wide road embankment 25.50 meters wide bandwidth, including the middle road both hard and 3.0 meters wide shoulder shoulder wide road and 3.0 meters 0.75 meters. Using cement concrete surface, grass-roots for cement-stabilized granular, cushion for 18cm gradation crushed stone materials (gravel). The main design includes: sure, the choice of highway grade route, linear curve elements calculation, paint line longitudinal diagram, vertical curve, typical drawing route computation elements, dredging, transverse route computation, design of high road pavement structure, protection engineering design, engineering, design of roadbed drainage budget and the construction organization design, the design of six, including culverts, dark circle culvert board GuanHan 5.
[Keywords]:Curve, vertical curve, drainage,embankment, cement concrete pavement,culverts
