本论文为武汉市某综合楼的空调系统设计。综合楼为舒适性空调,厨房采用独立的排风系统,空调方案选择了一次回风和新风加风机盘管系统,送风方式为散流器下送。综合楼设置了新风加风机盘管系统,具有较高的舒适度。计算过程夏季冷负荷采用谐波反应法,冬季采用了稳态法。为了达到节能的目的,设备的选择尽量使其高效率运行。空调机组按照系统冷量、风量、热量,选择了组合式空调机组。另外论文中说明了选择设备、数据的理由及其参考文献。论文的计算部分包括空调房间的负荷计算、风量计算和水力计算等。制图部分都采AutoCAD。本设计综合考虑了各方面因素,做到了满足舒适性与节能的要求,为生活提供了洁净和舒适的室内环境。
关键词:舒适性空调;综合楼;设计
This thesis is a complex building of Wuhan City air conditioning system design. Building for the comfort of air conditioning, kitchen with separate ventilation systems, air conditioning program and select a new air plus return air fan coil system, air supply diffusers under way for delivery. Building set a new air plus fan coil system with high comfort. Summer cooling load calculation using harmonic response method, using a steady state in winter. In order to achieve energy saving, the choice of equipment to efficiently run as possible. Air conditioning units in accordance with the system cooling capacity, air volume, heat, air handling units selected. Another paper describes the selection of equipment, data, reasons for their references. Calculation of part of the paper, including air-conditioned room load calculation, calculation of air volume and hydraulic calculation. Drawing parts are taken AutoCAD. The design took into account various factors, so that comfort and energy efficiency to meet the requirements for life to provide the clean and comfortable indoor environment.
Key word: Comfort air conditioning; Building; Design
武汉市某综合楼的空调系统设计.pdf
(1.22 MB, 下载次数: 7)
满意就快下载吧,纯word格式 |
