轻钢结构厂房设计论文摘要范文
  以下是土木毕设网小编为大家搜集整理的轻钢结构厂房设计论文摘要范文,供大家参考和借鉴!
  本设计工程为72米双跨钢结构,一跨带吊车,一跨有夹层,主要依据《钢结构设计规范》GB50017-2003和《门式刚架轻型房屋钢结构技术规程》CECS 102:2002等国家规范,综合考虑设计工程的规模、跨度、高度及用途,依据“适用、经济、在可能条件下注意美观”的原则,对各组成部分的选型、选材、连接和经济性作了比较,最终选用单层门式钢架的结构形式。梁、柱节点为刚性连接的门式钢架具有结构简洁、刚度良好、受力合理、使用空间大及施工方便等特点,便于工业化,商品化的制品生产,与轻型维护材料想配套的轻型钢结构框架体系已广泛应用于建筑结构中,本设计就是对轻型钢结构的实际工程进行建筑、结构设计与计算。主要对承重结构进行了内力分析和内力组合,在此基础上确定梁柱截面,对梁柱作了弯剪压计算,验算其平面内外的稳定性;梁柱均采用Q235钢,10.9级摩擦型高强螺栓连接,局部焊接采用E43型焊条,柱脚刚性连接,夹层梁与柱节点铰接;屋面和墙面维护采用压型钢板;另外特别注重了支撑设置、拉条设置,避免了一些常见的拉条设计错误。
  关键词:轻型钢结构门式钢架内力分析压型钢板节点
  Abstact
  The project situated in the suburbs of zhenjiang,jiangsu province.It is 72 meters in length and a 24-meter span seted two cranes and another span has a intercalated bed.The project designed strictly comply with the relavant stipulations of the“CODE FOR DESIGN OF STEEL STRUCTURES(GB50017-2003)”and“TECHNICAL SPECIFICATION FOR STEEL STRUCTURE OF LIGHT-WEIGHT BUILDINGS WITH GABLED FRAMES(CECS 102:2002)”,and some others.Synthesize the scale of the consideration design engineering and across a principle for span and use,according as"applying,economy,under the possible term attention utifully",Connecting method,structure type and material of each part which consist of a light-weight steel villa are analysed,then choose the construction form that use single layer a type steel.The beam,pillar node is a light steel construction frame system that rigid and copular a type steel a ware for having construction Simple,just degree goodly,suffering dint reasonablely,using space bigly and starting construction convenience etc.characteristics,and easy to industrialization,commercializing produce,thinking with light maintenance material the kit the already extensive applying in the building construction inside,this design is to proceeds the building,construction design to the structural and actual engineering in light steel and calculation.The tractate includes the internal force
  analyzes and combines,based on these analyse,we can choose the section of beam and columniation.Next,checking computations of stability calculation of the plane structure.The steel beam and column employs Q235 carbon structural steel.Connection bolts are high strenth bolt of friction type with behavoure grade
9.Common bolts are rough type made by Q235-B.F steel.Rod for mannual welding usually adopts E43.rigid connection apply to the column leg and the connection of column and beam adopts hinged connection.The metope and roofage adopts profiled steel sheet.Otherwise,it is analyzed that the forced state of the bracing system for a steel factor building under wind load,and the design of a bracing truss for a building with larger width.Avoid some errors in the design of brace,tention rod,tention rod joints.
  Keywords lightweight steel structures;gabled frame;the internal force analyzes;profiled steel sheet;joint
Current Value 1902
Update Date 2022-12-23
