住宅楼施工组织设计摘要范文
  本工程为一某小区多层住宅楼框架结构,一共六层,架空层一层,跃层一层,总用地面积781平方米,总建筑面积5423平方米。采用钢筋混凝土框架结构,平面布置比较灵活,受力良好,梁柱和楼板均为现浇。该地区地震设防烈度7度,框架为三级抗震。设计共分为二个部分:第一部分为建筑设计部分,包括工程概况、设计依据、标高及建筑细部作法;第二部分为施工组织部分,包括施工方案和施工方法、施工进度计划、确定施工平面图、质量保证和安全技术措施、资源供应计划等内容。
  关键词:住宅建筑施工
  Summary
  The project is a multi-storey residential building frame structure in a certain community,with six floors in total,one overhead floor and one duplex floor.The total land area is 781 square meters,and the total building area is 5423 square meters.The reinforced concrete frame structure is adopted.The plane layout is relatively flexible and the stress is good.The beams,columns and floors are cast-in-situ.The seismic fortification intensity in this area is 7 degrees,and the frame is Grade III earthquake resistant.The design is divided into two parts:the first part is the architectural design part,including project overview,design basis,elevation and construction details;The second part is the construction organization part,including construction scheme and method,construction schedule,determination of construction plan,quality assurance and safety technical measures,resource supply plan,etc.
  Key words:residential building construction
Current Value 2385
Update Date 2022-12-28
