办公楼建筑结构毕业设计论文中英文摘要范文
  以下就是土木毕设网为大家精心整理的办公楼建筑结构毕业设计论文中英文摘要范文。供大家学习。
  本设计主要进行了建筑、结构、施工三方面的设计。结构部分取5号轴线所在的框架进行抗震和构件设计。用底部剪力法计算水平地震荷载作用下大小,进而求出在水平荷载作用下的结构内力(弯矩、剪力、轴力)。接着计算竖向荷载(恒载及活荷载)作用下的结构内力,在计算结构内力是手算和迭代法。内力组合按照机算的结果进行组合,找出最不利的一组或几组内力组合。选取最安全的结果计算配筋并绘图。施工部分进行了地基及主体框架工程量计算,绘置了施工进度横道图和施工平面布置图;计算了各种机械的台班数。
  关键词:建筑框架结构设计抗震设计施工组织
  An Integrated Rural Industrial Park Office Building
  This design was the main building,structure,construction design in three areas.Structural part of the axis to take on the 5th framework where seismic and component design.Calculated using the bottom of the horizontal seismic shear loads,which controls the level of loads obtained in the structure of internal forces(bending moment,shear,axial force).Then calculate vertical load(dead load and live load)under the action of internal force,internal force is to begin in the calculation of the structure calculation and iterative methods.Internal force combination in accordance with the machine operator to combine the results,identify the most unfavorable internal force of a group or several groups of combinations.Select the most secure on the results of reinforcement and graphics.Construction of part of the foundation and the main framework of the engineering calculation,drawing set the construction schedule bar chart and the construction of floor plans;calculate the number of classes of various mechanical units.
  Keywords:Structure Frame Structural design Seismic Design
  Construction Organization
Current Value 2445
Update Date 2023-07-24
