土木工程住宅楼毕业设计论文摘要
  以下是土木毕设网小编为大家搜集整理的土木工程住宅楼毕业设计论文摘要,供大家参考和借鉴!!
  该计算书主要包括八个部分:结构选型、水平力作用下的框架结构计算、竖向荷载作用下的内力计算、横向框架内力组合、截面尺寸设计、板的设计、基础设计、楼梯设计。
  设计主体是六层框架结构,选择一榀框架计算。
  框架结构的计算部分包括:梁板柱尺寸的初步确定,重力荷载标准值的计算,横向框架侧移刚度的计算,水平地震力作用下的内力计算和侧移计算,水平风荷载作用下的侧移验算。
  竖向荷载作用下的框架内力计算,主要包括恒荷载和活荷载作用下的内力计算。
  内力组合主要是水平地震作用、恒荷载作用、活荷载作用之间的组合。
  截面设计包括梁的截面设计和柱的界面设计,梁的界面设计包括正截面验算和斜截面验算,柱的截面设计包括轴压比的验算和正截面验算和斜截面验算和结点设计。
  板的设计采用的是单向板。
  基础设计包括荷载计算,基础承载力计算,冲剪验算,基础配筋计算。楼梯设计包括梯段设计、平台梁设计、平台板设计、楼梯的配筋计算。
  关键词:框架结构、基础、梁、柱、板、楼梯
  abstract
  This calculation sheet mainly includes eight parts:structural selection,frame structure calculation under horizontal force,internal force calculation under vertical load,lateral frame internal force combination,section size design,plate design,foundation design,and staircase design.
  The design subject is a six story frame structure,and one frame is selected for calculation.
  The calculation part of the frame structure includes:preliminary determination of the size of beams,slabs,and columns,calculation of the standard value of gravity load,calculation of lateral stiffness of the frame,calculation of internal force and lateral displacement under horizontal seismic force,and verification of lateral displacement under horizontal wind load.
  The calculation of frame internal forces under vertical loads mainly includes the calculation of internal forces under constant and live loads.
  The combination of internal forces mainly refers to the combination of horizontal seismic action,constant load action,and live load action.
  Section design includes beam section design and column interface design.Beam interface design includes normal section verification and oblique section verification.Column section design includes axial compression ratio verification,normal section verification,oblique section verification,and node design.
  The design of the board adopts a unidirectional board.
  Basic design includes load calculation,foundation bearing capacity calculation,punching and shearing verification calculation,and foundation reinforcement calculation.Staircase design includes stair segment design,platform beam design,platform slab design,and reinforcement calculation of stairs.
  Keywords:frame structure,foundation,beams,columns,slabs,stairs
Current Value 2019
Update Date 2024-01-27
