建筑地点:阳泉 construction Site: YangQuan
结构形式:框架结构 construction Systen: Frame structure
建筑面积:6021.5m2 floor Area: 6021.5m2
层数/高度:5层/21.6m stories/Height: 5 stories/21.6 m
主要用途:商场 、办公 main Use: Shopping、office
关键词:
框架结构 frame structure
现浇混凝土 cast-in-place concreate
条形基础 spread footings
屋面板 roof plate
正截面 normal section
根据教学要求入手,从“灵活使用”的角度出发,绿化与建筑相结合,改善外部购物环境。内部采用大、中、小不同的空间尺寸以及斜线、曲线等不同的要素,构成了富于层次流动感强的浓郁的气氛。
宏利商场是一座集购物、餐饮、办公为一体的综合的现代商厦在设计理念上,力求充分体现现代化一流商厦的特点和友谊商厦的特性。在整体造型上突出现代、新颖、做到简洁、明快、虚实相接、刚柔相济、给人以蓬勃向上的感觉。设计上采用钢结构、外装饰铝板、拉索点式玻璃幕墙等新技术、新材料、突出钢结构特点,钢、玻璃、铝板有机结合,创造一个满足功能、符合环境、有鲜明现代性的建筑形象。透过通透落地玻璃幕墙,使室内、室外空间相互交融,同时作为窗口,使商厦的景物景象展示给路人
"Flexible use"and combination of greening and building latgely improve its outside shopping environment.In the inside,laige,medium and small--sized spice,togethei with the various building elemenrs like diagonal and curve,creates a dense atmosphere.Xin'Plaza conveys the traditional charm of modern architecture,and effectively billboatd.
Geri Plaza is an integrated including shopping,restaurants,entertainment cente and offices.In terms of design concept,the designers tried to fully materialize both the general features offirst-class modem shopping mall and the unique identity of FriendshipShopping Mall.In terms of overall form,this shopping mall gives priority to modernism and novelty ---its concise and lively shape conveys a sense of vigor and aggression.Steel strure,aluminum plate outerdecoration and suspended cable point glass curtain wall and other mew technique and materials are introduced into thedesign,giving prominence to the characteristic of steel structure.The harmonious combination of steel,glass and aluminum pate creates an idantity of modem atchitecture that can not only meetthe functional requirements but also assort with the envuribnebt.The transparentfloor glass curtain wall makes the outdoor and indoor space meet.And it is also a window,showing the passersby the indoor scenery of the shopping mall.
建筑面积:6021m2
建筑层数:5层
建筑高度:21.6m
某市某5层框架商场毕业设计(计算书 图纸)[面积6021].pdf
(2.67 MB, 下载次数: 0, 售价: 1 积分)
