本工程建筑面积约15100㎡。本设计采用框架结构,地上主体部分六层,地下一层为地下车库。本地区抗震设防烈度为6度。基本风压0.45kN/㎡,地面粗糙度为D类。
本设计包括建筑设计部分和结构设计及结构计算部分,重点是对结构进行合理的布置、确定和计算。主要进行了结构方案中横向框架的一榀框架(G轴)结构设计及配筋计算并完成施工图。在确定框架布局之后,设计框架各截面尺寸,进行横向、竖向荷载计算,再对结构进行内力分析及内力组合,最终计算框架配筋并绘图。
关键词 建筑设计 结构设计 框架结构 内力分析
This project construction area of about 15100 square meters. This design uses frame structure, the main part of six floors, underground for underground garage. This region seismic fortification intensity for six degrees. Basic wind 0.45kN/㎡, ground 0.45 roughness as D.
This design including the architectural design and structure design and structure, key is calculated for part of the layout, reasonable structure and calculation. The main structure scheme of frame transverse investigated.one (G) structure design and calculation and complete documentation. In determining the layout, design frame frame transverse dimensions, each section, vertical load calculation, analysis of structure and internal force calculation, and finally framework of reinforcement drawings.
Keywords architectural design structure design frame structure internal force analysis
建筑面积:15100m2
建筑层数:6层
建筑高度:29.3m
文件内容:计算书+图纸+任务书+开题报告+实习报告
杭州某6层框架宾馆毕业设计(计算书 图纸)[面积15100].pdf
(1.17 MB, 下载次数: 2, 售价: 1 积分)
