本设计以 某商厦为例阐明了框架 - 剪力墙商层建筑结构设计的一般过程,以单片结构的设计阐述了框架、剪力墙部分结构设计的步骤,通过些设计,使零散的理论知识 系统化,同时还掌握了结构设计的内容,为以后就业奠定扎 实的基础。
建筑设计以适用 、经济 、美观的总体要求 ,建筑平面简洁、 明快、体现时代待征,结构方案合理,体系选择准备、技术 先进、利于施工,装饰简洁适用、经济。功能综合,下为商 服,上做为写字楼,采用大开间的形式为使用者一定的设计 空间作为分割功能区之用。
哈尔滨市地处严寒地区 ,考虑 寒冷地区的特点 ,为了满足 保温要求本建筑外墙用 300 ㎜厚陶粒砼,造型朴素明朗,整 洁淡雅。为满足立面造型的美观采用幕墙装饰,这样既满足 了当今的现代化写字楼要求,又有了整体美观的效果。
关键词:高层建筑、结构设计、框架 - 剪力墙结构
Summary design and revitalize commercial building expound frame cut trader of strength wall layers of building general course who structure design at - for example with Harbin China originally, At single ones the designs of structure explain frame, cut strength wall No. some, At designs, systematize scattered theory knowledge and grasp content who structure designed also at the same time, Establish the sturdy foundation for the employment. At suitable, economy, beautiful general requirement, succinct architectural design lucid and lively, The structure scheme is rational , choose preparing, modern techniques, do benefit to constructing in system, Decorate succinct suitable . Synthesize functions,make it is trader clotheseses,on make, Adopt the great design space with certain for user form which makes one as cutting apart the using of the function district. Harbin locate in severe cold area and consider cold the characteristics of areas is for satisfying and keep warm request spend 300 mm thick ceramsite concrete by copies of building outer wall by city, The modelling is simple and clear, neat and simple and elegant. For satisfying and stand modelling beautiful adoption decorate by scene wall surface, already satisfied the nowadays modernized office building request like this, There is result with beautiful whole .
The keyword: Skyscraper, structure design , frame cut strength wall structure
某12层商场-写字楼建筑结构设计计算书.pdf
(1.72 MB, 下载次数: 0, 售价: 1 积分)
满意就快下载吧,纯word格式 |
