简支梁布局
简支梁布局
% S3 Q# t2 @- Y一个简单的预应力混凝土梁由两个危险截面控制:最大弯矩截面和端截面。这两部分设计好之后,中间截面一定要单独检查,必要时其他部位也要单独调查。最大弯矩截面在以下两种荷载阶段为控制情况,即传递时梁受最小弯矩MG的初始阶段和最大设计弯矩MT时的工作荷载阶段。而端截面则由抗剪强度、支承垫板、锚头间距和千斤顶净空所需要的面积来决定。所有的中间截面是由一个或多个上述要求,根它们与上述两种危险截面的距离来控制。对于后张构件的一种常见的布置方式是在最大弯矩截面采用诸如I形或T形的截面,而在接近梁端处逐渐过渡到简单的矩形截面。这就是人们通常所说的后张构件的端块。对于用长线法生产的先张构件,为了便于生产,全部只用一种等截面,其截面形状则可以为I形、双T形或空心的。在第5 、 6 和7章节中已经阐明了个别截面的设计,下面论述简支梁钢索的总布置。8 r: u; [5 d% O
2 G  Z/ t) E) E* oSimple Beam Layout3 m. J4 v7 x  {
The layout of a simple prestressed-concrete beam is controlled by two critical sections: the maximum moment and the end sections. After these sections are designed, intermediate ones can often be determined by inspection but should be separately investigated when necessary. The maximum moment section is controlled by two loading stages, the initial stage at transfer with minimum moment MG acting on the beam and the working-load stage with maximum design moment MT. The end sections are controlled by area required for share resistance, bearing plates, anchorage spacings, and jacking clearances. All intermediate sections are designed by one or more of the above requirements, depending on their respective distances from the above controlling sections. A common arrangement for posttensioned members is to employ some shape, such as I or T, for the maximum moment section and to round it out into a simple rectangular shape near the ends. This is commonly referred to as the end block for posttensioned members. For pretensioned members, produced on a long line process, a uniform I, double-T, or cored section is employed throughout, in order to facilitate production. The design for individual sections having been explained in Chapters 5, 6, and 7,the general cable layout of simple beams will now be discussed.( s* j9 z8 A: }. t( C# R! |
; |: X: x* P- ^) A) w: R
下载完整外文译文,纯word格式
Current Value 15329
Update Date 2015-11-28
