Damage Model Based Reinforced-Concrete Element
Chee Kiong Soh1; Yu Liu2; Yue Xing Dong3; and Xin Zheng Lu4
Abstract:
In this paper, the damage in concrete around a reinforcement bar is examined, and three types of damage in concrete and at the concrete-rebar interface are defined. Based on these definitions, a three-dimensional damaged reinforced-concrete ~DRC! element is proposed. The element consists of a 10-node concrete element, a two-node rebar element, and a four-node concrete-rebar interface
element. Experiments were carried out to obtain the parameters for the bond damage evolution equation. The proposed DRC element is implemented as a user-defined element of MSC MARC2000, a commercial finite-element analysis software package. Two numerical examples were examined, and the results show that the DRC element can simulate the bond deterioration in reinforced-concrete structural members with sufficient rationality, accuracy, and efficiency.
DOI: 10.1061/~ASCE!0899-1561~2003!15:4~371!
CE Database subject headings: Damage; Models; Concrete, reinforced.
损伤模型为基础的钢筋混凝土构件
摘要:
在本论文中,讨论了加强钢筋周围的混凝土的破坏情况,将混凝土钢筋破坏界面的界定为3种类型。根据这些定义,提出了高强混凝土的三维破坏原理。这个原理包含三个元素,分别是一个10节点的混凝土构件,两节点筋单元,和一个四节点的混凝土钢筋接口。进行了试验,以取得弯矩破坏公式的有关参数。数据控制记录被建议作为MSC MARC2000的一个用户定义元素,MSC MARC2000是一个商用有限元分析软件包。两个数值实例研究结果表明,数据控制记录元素可以合理精确有效的模拟高强混凝土黏结失效。
CE数据库主题词:破坏;模型;混凝土,加固。
下载完整外文译文,纯word格式
