辽宁机电职业技术学院教学楼
本项目为辽宁机电职业技术学院教学楼,为毕业设计项目, 位于沈阳市文化路和热闹路交接处。该项目主要用于学校教学,主要包括教室,实验室,办公室等教学用房。
本项目占地面积约1681.62平方米,建筑面积7567.29平方米。项目主体五层,局部四层,层高均为4.2米,总高度21.60米,室内外高差为0.60米。建筑总长度为88.22米,设有两道抗震缝,其宽度为100mm。建筑设计使用年限为50年,建筑物的耐火等级为三级。
该建筑结构形式为现浇钢筋混凝土框架结构,框架柱混凝土强度等级为C30,柱截面为500 500 mm ,框架梁混凝土强度等级为C25,纵向框架梁截面为300 600 mm ,横向框架梁截面为300 550 mm ,其中走廊横向框架梁截面为300 300 mm 。女儿墙用混凝土现浇,墙体均采用空心砖砌筑。建筑地点地质条件良好,采用柱下独立基础,基础埋深为1.8m,混凝土强度等级为C25。经济符合要求。
设计严格遵守我国现行规范,计算中包括地震荷载计算,风荷载计算, 内力组合,框架梁设计, 框架柱设计, 基础设计,楼板设计, 楼梯设计。
关键词:毕业设计 框架结构 教学楼 钢筋混凝土
The project is a teaching building of Liaoning Mechanical Professional technical institute, which belongs to a graduation project. It lies in the joint of the Wenhua Road and Renao Road in Shenyang. The project is used for teaching for school, and it contains classrooms, laboratories, offices and so on.
This project covers an area of 1681.62 square meters, and the floor space are 7567.29 square meters. The building is five storeys high and four storeys in some parts. Total height of this building is 21.60m, and the difference of height between indoors and outside is 0.45m. The total length of the building is 88.22 m, and there are two avoiding shaking seams which are 100mm wide during it. The designed service life of the Architecture is fifty years, and the construction fire protection rank is three rank.
The structural form of the civil engineering is reinforcement concrete casting frame .The strength class of the frame column is C30, and the cross sections of column is 500 500 mm . The strength class of the frame beam is C25, the cross sections of the vertical beam is 300 600 mm and the cross sections of the later beam is 300 550 mm while the later beam of corridor is 300 300 mm . The daughter wall is builded by reinforced concrete, and the other wall is used hollow bricks. The soil condition of the building site is good, so use under column independent foundation with the concrete of C25, and the depth of the foundation is 1.8m. The design meet economy needs.
The design strictly complied with the currently used code of our Country. The calculation includes the calculation of the earthquake load and wind load, the composition of internal force, the design of frame beam and column, the design of the foundation and the calculation of the stairs , boards and rain loose.
Key words: graduation project frame structure teaching building
reinforced concrete
建筑面积:7567m2建筑层数:5层
建筑高度:25.2m
计算书.pdf
(7.73 MB, 下载次数: 0, 售价: 1 积分)
