天水分路口小区5号楼结构设计
作者:刘合旭 指导老师:何斌
摘 要:本工程为天水分路口小区5号住宅楼工程,采用框架结构,主体为六层,局部七层,本地区抗震设防烈度为8度,场地类别为II类场地。主导风向为西北,基本风压0.35KN/m2,基本雪压0.20 KN/m2。楼﹑屋盖均采用现浇钢筋混凝土结构。本设计主要进行了结构方案承重体系的选择;在确定框架布局之后,根据工程经验,对梁、柱进行截面尺寸和板的厚度的初选,然后根据已给的建筑做法求楼屋面,墙体窗户的均布荷载,接着应用PKPM软件PMACD模块进行建模,应用TAT—8模块进行框架计算,框架梁柱的施工图绘制.此外还进行了结构方案中的室内楼梯的设计,完成了平台板,梯段板,平台梁等构件的内力和配筋计算及施工图绘制;对采用的独立基础尺寸进行选择和底板受力和配筋计算,并绘制施工图绘制。
整个结构在设计过程中,严格遵循相关的专业规范的要求,参考相关资料和有关最新的国家标准规范,对设计的各个环节进行综合全面的科学性考虑。总之,适用、安全、经济、使用方便是本设计的原则。
关键词:框架结构;PKPM;荷载计算;TAT-8;计算配筋
THE STRUCTURE DESIGN OF #5 BUILDING AT THE JUNCTION DISTRICT IN TIANSHUI CITY
ABSTRACT:This works is for #5 residential building projects at the junction district in tianshui city, a framework structure for a six-storey main, in the region earthquake intensity of 8 degrees ,classification as Class II venues.Led to the northwest direction, the basic Pressure 0.35KN/m2, basic snow pressure 0.20KN/m2. Floor and roof are using cast-in-place reinforced concrete structure. The design choice a major load-bearing structure of the system . After determining the framework of the layout, the first based on engineering experience,choice a section size of the beams, columns and the plate thickness of the floor, then had to calculat the uniform load of the construction floor, roof , wall and windows , then applicate the software PMACD- PKPM Modules for modeling, TAT-8 modules for calculation,and map the beams 0f the framework for the construction. In addition, design the indoor staircase of the structure.Complete internal forces calculation of the platform boards, boards of the ladder,platform beam component, reinforcement,and map for construction.This design uses an independent foundation,Choice the size,calculate the bottom edge and reinforced, and map for construction.
The whole structure of the design process, in strict compliance with the relevant professional standard, reference to relevant information and the latest national standards and specifications, and design of the various components of a comprehensive scientific considerations. In short, application, security, economic and user-friendly design is the principle.
KEYWORDS:Frame Structure;PKPM;Load Calculation;TAT-8;Calculation reinforcement
建筑面积:3969m2
建筑层数:7层
建筑高度:17.85m
计算书.pdf
(3.62 MB, 下载次数: 0, 售价: 50 积分)
