本建筑为 沈阳瀚林苑图书馆,位于沈阳市区。共五层,底层为书库,二层为借阅大厅,三至五层为办公用房,总建筑面积:7498.05 ,占地面积:1600 ,一层层高4.2m,标准层3.6m,顶层层高3.9m。室内外高差0.600m,室外绝对标高为+18.9m。
为满足防火要求,本建筑结构内设置三个双跑楼梯和两部电梯。墙体采用粘土砖空斗砌体(卫生间处隔墙采用C型轻钢龙骨隔墙),室内地面采用大理石装饰。门为实木门,窗采用塑钢玻璃窗。屋面为不上人屋面,采用改性沥青防水,苯板保温。
该建筑抗震设防类别为丙类,地震作用及抗震措施均按设防烈度考虑。建筑结构采用钢框架结构。由于本建筑为5层,框架柱采用H形截面,框架梁采用焊接工字形截面。柱子之间可不设柱间支撑。楼板采用压型钢板钢筋混凝土组合结构;楼梯采用组板式楼梯;基础形式为独立基础。
考虑到建筑物外观美观,提高使用空间的采光率,一层至五层采用局部玻璃幕墙装饰。
关键词:钢框架结构; 内力组合;组合楼板。
This is shentong comprehensive building , in Shenyang city proper . All of this building is 5 floors , the first and senond floors are business hall , and the third to nine floors are handle official business rooms , the total area of building is 7498.05 ,the area of building’s occupy is 1600m2. The height of the first and senond floors’ are 4.2m , the height of standard floors are 3.6m ,the end floors are 3.9m. The balance between indoor and outdoor is 0.600m , the absolutely height of outdoor is +18.900m .
To satisfied the demand of fire prevention , there are two stairs and two lifts have been set up in this building structure . In this building , walls are made of concrete hollow block ( the partitions used in toilets are made of the light-duty steel , which has the model of “ C ” ) . Doors are made of wood , and the windows are made of plasticity toughened glass. The roof is not used to been steped on , the transform asphalt has been used for waterproof , the plank has used for heat preservation .
The seismic fortification intensity of this building is bing type , the action of earthquake and the measure of seismic are considered of seismic fortification intensity . The structure of building is steel frame . For this building has 5 floors , the type of this building’s pillar is chest , and the type beam is “ H ” . Between the pillars , there needn’t sustains . The floor’s type is light-duty reinforced concrete structure ; the stair is made of combination beam ; and this structure adopt pile foundation .
To make the exterior of building more beautiful , and promote the daylighting’s use ratio of apply room , glass curtain wall is used to part of 1to5 floors 。.
Key word: Steel frame structure; Internal force combination; Knockdown floorslab.
建筑面积:7495m2
建筑层数:5层
建筑高度:19.800m
结构类型:钢框架结构
文件内容:计算书+图纸+任务书+文献翻译
计算书.pdf
(4.89 MB, 下载次数: 0, 售价: 5 积分)
