本工程是多层旅馆设计,为多层钢筋混凝土框架结构。共六层一层高3.6米,二到五层层高为3.6米,六层高4.2米,建筑物总高度为22.2米。
该计算书主要包括:框架结构设计任务书、框架结构设计计算部分(横向水平荷载作用下的框架结构的内力和侧移计算、竖向荷载作用下框架结构的内力计算、内力组合、截面尺寸设计)。设计主体是六层框架结构,选择一榀框架计算,框架结构的计算部分包括:梁板柱尺寸的初步确定、重力荷载标准值的计算。横向框架侧移刚度的计算、水平地震力作用下的内力计算与侧移计算,竖向荷载作用下的框架内力计算(用分层法),主要包括恒荷载和活荷载作用下的内力计算,内力组合主要是水平地震作用、恒荷载作用、活荷载作用之间的组合,截面设计包括梁的截面设计和柱的截面设计,梁的截面设计包括正截面验算和斜截面验算,柱的截面设计包括轴压比的验算和正截面验算和斜截面验算和结点设计。板的设计采用的是双向板。基础设计包括荷载计算,基础配筋计算。楼梯设计包括梯段设计、平台梁设计、平台板设计、楼梯的配筋计算。
关键词:办公楼;框架;截面设计;平面布置
This project is multi hotel design, multi-layered reinforced concrete frame structure. A total of six, first storey 3.6 meters, two to five storey 3.6 meters, six storey 4.2 meters,building a total height of 22.2 meters.
The calculations include: frame design task book, frame design internal forces and drift calculation section frame structure (under transverse horizontal load calculations, the internal forces under vertical load frame structure calculations, internal force, cross-sectional dimension design ). Design of the main frame structure is six, select a Pin Frames calculating portion of the frame structure comprising: determining the initial size of the slab column, calculate the gravity load standard values. Calculated transverse frame lateral stiffness and internal force calculation under horizontal seismic force and lateral basis, internal force calculation under vertical loads (with stratification), including the calculation of internal forces under dead and live loads, internal force is mainly horizontal earthquake, constant loads, live loads combination between the cross-sectional design includes a cross-sectional design of the beam and column section design, the design of the beam cross section including normal section checking and checking oblique section, a cross-sectional design column including axial compression ratio of normal section checking and checking and checking oblique section and junction design. Board design uses a two-way plate. Foundation design includes load calculation, foundation reinforcement calculation. Staircase design includes bench design, platform beam design, platform board design, reinforcement calculation stairs.
Key words: building; cross-sectional design;; frame layout
建筑面积:6200m2
建筑层数:6层
建筑高度:22.20m
文件内容:计算书+图纸+实习报告
论文计算书.pdf
(5.85 MB, 下载次数: 0, 售价: 5 积分)
