本设计为拟建的办公楼,主要包括两部分。一是建筑方案设计,根据任务书的功能要求选择合理的柱网尺寸和结构形式来布置建筑的主要用房,并且选择合理的工程做法;二是结构方案的设计,选取一榀典型框架进行设计计算。在明确计算简图的前提下,进一步确定框架承受的荷载,包括恒荷载、屋(楼)面荷载,在此基础上进行框架内力计算(采用D值法计算风荷载作用下的内力,采用弯矩二次分配法计算竖向荷载作用下的内力)、内力组合、梁、柱和基础等构件的配筋计算。
通过本次毕业设计,我对框架结构设计过程有了更深刻的了解。
关键词:框架;建筑设计;结构设计;内力计算;配筋计算
The design for the revitalization of Guangzhou City office building, mainly consists of two parts. One is the architectural design, the main room to decorate a building according to the grid size and structure of the functional requirements of the task book selection, and select rational engineering practice; two is the structural design, select a typical framework design. In the explicit calculation diagram under the premise, further determining the frame under load, including dead load, house (floor) surface loads, based on the calculation of internal forces of frame (the D value method to calculate the internal force, wind loads of the moment two methods of distribution to calculate the vertical load of the internal forces, the calculation of reinforcement) the combination of internal forces, beam, column and foundation member.
Through this graduation design, I have a more profound understanding to the frame structure design process.
Keywords: Frame Building;Structure Design;Calculation of Internal Force;Calculation of Reinforcement
建筑面积:4500m2
建筑层数:5层
建筑高度:20.5m
