中文摘要
本工程为某轻型钢结构门式刚架设计。根据毕业设计任务书的要求,分建筑与结构两部分进行设计。
建筑部分,通过查阅《钢结构设计规范GB50017-2003》、《简明钢结构设计手册》、《福建省建筑设计标准图籍》等相关资料,将门式刚架厂房设计为13跨,每跨的间距为30m,总的建筑面积为2160m2。该单层门式刚架结构是以轻型焊接H型钢(变截面)作为主要承重骨架,用冷弯薄壁型钢(C型)做檩条、墙梁;以压型钢板做屋面、墙面;采用80mm玻璃棉作为保温隔热材料并适当设置支撑的一种轻型房屋结构体系。
结构部分,根据已形成的建筑图及其相关要求,查阅《建筑结构荷载规范GB50009-2001》、《冷弯薄壁型钢结构技术规范GB50018-2002》、《钢结构连接节点设计手册》、《房屋建筑钢结构设计》等相关规范和一定量的实际工程设计图,对每榀刚架的最不利荷载进行计算,利用PKPM软件完成刚架的合理截面计算,然后通过设计规范的相关要求,对刚架梁、柱、支撑、檩条等构件进行稳定性计算,用AUTOCAD2005分别绘制出设计图。最后,整理计算书并出图。
关键词:轻型钢结构门式刚架 建筑 结构 规范 设计图
This project is a light steel portal frame design. Under the graduation requirements of the task book, divided into two parts building and structure design。
Building part, by access to the 《Steel Structure Design Specification GB50017-2003》、《Concise Steel Structure Design Manua》、《The Fujian Architectural Design Standard Plans》and other relevant information, the gabled designed to 13 across each cross-a 30m, total construction area for 2160m2. The single-storey gabled structure is to light welding h-shaped steel (uniform) as the main load bearing frame, with cold-formed steel (type c) do Purlin beams and walls; to steel do roofing, wall; a 80mm glass wool as an insulation material and appropriate settings supported a light house in architecture.
Structural elements, according to the established building plans and related requirements, consult the《Building Structure Load Code GB50009-2001》、《cold-formed steel structures specification GB50018-2002》、《steel structure connection node design manual》、《the housing construction steel structure design》and other related specifications and a certain amount of actual engineering design, each truss pin of the most unfavorable load calculations, use PKPM software complete the rigid frame of reasonable section, and then through the design specifications of requirements on the rigid frame beams and columns, such as support, purlins, component for stability with AUTOCAD2005 respectively out design. Finally, a finishing account book and plot.
Key Words:Lightweight gabled Building Structure Specification Design Sketch
建筑面积:2160m2
建筑层数:单层
建筑高度:8.00m
结构类型:钢结构
钢结构毕业设计1.pdf
(2.01 MB, 下载次数: 0, 售价: 10 积分)
