[摘 要]本设计包括两大部分:建筑结构设计、投标文件的编制。在查阅相关资料,根据现行的建筑结构设计规范及标准,确定建筑结构方案后,用CAD软件绘制出建筑施工图。然后分析计算各种荷载,用PKPM软件进行内力计算、内力组合、配筋计算(包括梁、板、柱、基础及楼梯的配筋计算),并绘制出结构施工图。在建筑结构设计完成后,根据建筑结构图纸和工程量计算规则分别进行清单工程量和定额工程量的计算,并用软件完成工程量清单和投标报价。此外,还进行了投标文件的编写。
[关键词]建筑设计;结构设计;投标文件
[Abstract]
This project design consists of two parts: architectural and structural design, bid document establishment . After the determination of architectural and structural program by referring to related informations and current architectural and structural codes and specifications, the architectural constructional drawing is plotted by the CAD software. Then the loads of different cases are calculated by hand and the internal forces analysis, internal force combination, the reinforcement calculation of the beam, the slab, the column, the foundation and the staircase are conducted by the PKPM software. Besides, the structural constructional drawing is finished by the PKPM software. Following the architectural and structural design, quantities are calculated based on engineering quantity calculative codes and the engineering quantity list and the bidding base price are carried out by the XTY software. Moreover, has carried on the bid document compilation.
[Key words] architectural design; structural design; tender documents
建筑面积:250m2
建筑层数:2层
文件内容:投标文件+图纸
