水利水电建设是国家基本建设的一个组成部分,组织工程施工是实现水利水电建设的重要环节。施工组织设计是研究施工条件、选择施工方案、对工程施工全过程实施组织和管理的指导性文件、是编制工程投资估算、设计概算和招标投标文件的主要依据。合理科学的施工组织设计对工程的成功完建有着重要指导作用,有利于施工的合理有序进行。
汤旺河应急供水工程坝址位于伊春河干流与挡石河汇合口下游处,距翠峦区约2km。是一座以防洪和供水为主,兼顾发电、灌溉等综合利用功能的大型水利枢纽工程。通过对汤旺河应急供水工程概况、工程布置及施工条件的分析,作了该工程施工导流方案和泄水建筑物——溢洪道工程的施工设计。
关键词施工组织设计; 施工导流 ; 溢洪道; 施工总体布置
Hydropower construction of a national infrastructure component, Tissue Engineering Construction hydropower is an important part of the building. Construction design study for the construction, the construction program choice, Construction on the entire process of organization and management of the implementation of the guiding document, is to produce estimates of project investment, budget for the design and bidding documents based primarily. Reasonable scientific construction design of the project has successfully completed construction of important guiding role conducive to the construction of a rational and orderly manner.
Western Hills Reservoir Dam in Yi Chun River blocks Shi he River confluence with the downstream population, cuiluan distance of about 2km. Is a flood control and water supply in the main, the balance between power generation and irrigation comprehensive functions such as large water control project. By Xishan Reservoir Project Profiles, the layout and construction conditions, Construction was the diversion program and discharge structures -- the construction of spillway design, Construction of the transportation and other temporary facilities construction the overall layout, and the spillway works budget.
Keywords Construction design; Diversion; Spillway; Construction of the overall layout
1. 前言
1.1 枢纽概况
1.1.1 枢纽位置
汤旺河应急供水工程位于黑龙江省伊春市翠峦区西北2km伊春河干流上,坝址地理坐标为东经128°27′~128°41′36″,北纬47°36′~47°51′。
伊春河发源于小兴安岭腹地陈阿布伦山,自西向东流经伊春中心城市的翠峦、乌马河和伊春区,于伊春区东北部汇入汤旺河,属于汤旺河上游右岸一级支流,流域总面积2472km2,坝址控制面积1613km2。汤旺河由北向南流经伊春区的东部,流域总面积20838km2,伊春区以上流域面积10272km2。水库坝址以下有伊春河的支流乌马河由南向北流经乌马河区从右岸汇入伊春河。
1.1.2 枢纽功能
汤旺河应急供水工程是一座以防洪和供水为主,兼顾发电、灌溉等综合利用功能的大型水利枢纽工程。建成后,配合城区堤防建设可将伊春市的防洪标准提高到50~100年一遇,为伊春市和伊春河沿岸城镇提供1.4亿立方米的供水水源,发展灌溉面积1.8万亩,此外,还具有为伊春市增加电力供应、提供森林灭火水源、改善枯水期水环境等综合利用功能。
1.1.2.1防洪
伊春河是洪水多发性河流,洪水灾害发生次数多,造成的损失大,仅建国50余年中发生灾害性洪水有10年,平均每5年发生一次。泥石流、山洪等破坏性极大的局部洪灾也时常发生,特别是1985年特大洪水,城市堤防被冲跨,洪水淹了大半个城区,造成直接经济损失1.73亿元(当年价)。所以伊春市列为黑龙江省重点防洪城市,但当前防洪标准偏低,为了从根本上解决伊春河洪水威胁,只有在干流上修建控制性工程,拦蓄山洪,削减洪峰,再配合城区堤防建设,才能有效地提高防洪标准。因此,修建汤旺河应急供水工程,采取库堤联合防洪方案,变水害为水利,彻底根治水患是伊春市当前十分紧迫的战略任务。
摘 要 I
Abstract II
1. 前言 1
1.1 枢纽概况 1
1.1.1 枢纽位置 1
1.1.2 枢纽功能 1
1.2 工程等别及建筑物级别 3
1.2.1 工程等级 3
1.2.2 溢洪道工程布置 3
1.3 溢洪道工程地质条件 4
2. 施工条件 5
2.1 地理位置与对外交通 5
2.2 工程布置 5
2.3 施工条件 5
2.3.1 气象水文 5
2.3.2 建筑材料 7
2.3.3 水电条件 8
2.3.4 施工期 8
2.3.5 施工特点 8
3. 施工导流 9
3.1 导流标准与导流方案 9
3.1.1 导流标准 9
3.1.2 导流方案 9
3.1.3 导流程序 9
3.1.4 导流流量 10
3.2 导流建筑物设计 14
3.2.1 挡水建筑物 14
3.2.2 泄水建筑物 16
3.3 导流建筑物施工 18
3.3.1 施工时段与流量选择 18
3.3.2 料场规划 18
3.3.3 上下游围堰施工 19
3.4 截流 20
3.4.1 截流时段及标准 20
3.4.2 截流方案 20
3.4.3 截流水力计算 21
3.5 基坑排水 24
3.5.1 初期排水 24
3.5.2 经常性排水 25
4. 主体工程施工——溢洪道工程 28
4.1 施工总体安排 28
4.2 土石方开挖工程 28
4.2.1 土方开挖工程 28
4.2.2 石方开挖工程 29
4.3 基础处理 31
4.3.1 灌浆施工 31
4.4 混凝土骨料 33
4.4.1 骨料料场与骨料用量 33
4.5 混凝土浇筑 34
4.5.1 混凝土运输 34
4.5.2 混凝土施工主要设备 35
4.5.3施工不出现冷缝混凝土供应强度计算 37
4.5.4 混凝土浇筑程序 37
4.5.5 混凝土仓面作业机械 39
4.5.6 混凝土的冬夏季施工 40
4.5.7 混凝土的二次浇筑 40
4.6 引水渠和海漫段施工 40
4.7 施工交通运输 41
4.7.1 对外交通 41
4.7.2 场内交通运输 41
4.8 其他设施 42
4.8.1 施工工厂设施 42
4.8.2 附属企业各厂 42
4.8.3 风、水、电、通信及照明 42
5. 施工总布置 44
5.1 施工总布置 44
5.1.1 布置原则 44
5.1.2 分项布置 44
5.1.3 施工临时房屋 45
6. 施工总工期 47
6.1 施工安排 47
6.1.1 施工进度安排 47
结 论 48
参考文献 49
致 谢 50
部分内容展示
文件名:某河应急供水工程溢洪道部分施工组织设计(设计书 图纸).rar
