该毕业设计是威海市大学法律学院的六层教学楼设计,采用了框架结构,并且是横向承重体系,在设计时,包含了建筑设计和结构设计,建筑设计部分包含了建筑平面、剖面、立面的设计,在结构设计部分主要是从该教学楼的框架结构中取出一榀框架进行计算,内容主要包括结构布置、荷载统计、荷载作用下的内力计算、在水平荷载作用下的位移的验算、内力的调整、内力的组合,其中对竖向荷载作用下的内力计算采用弯矩二次分配法,水平荷载作用下的内力计算采用D值法,在求地震作用下的楼层作用时采用了底部剪力法,然后采用最不利的内力进行框架结构的配筋计算,对梁柱进行截面设计时要根据强柱弱梁、强剪弱弯、强节点弱构件的原则进行内力的调整,另外还包含一些构件的计算,如板和楼梯。
关键词:荷载;框架;结构设计;内力;配筋
The graduation project is the design of weihai city university law school six story classroom building ,the frame structure ,and horizontal load-bearing system ,including architectural design and stuructural design ,architectural design section contains a construction plane,profile ,verticalsurface design ,structural design part of the framework to calculate a specimens of removed from the framework structure of the teaching building,including structural arrangement of checking the horizontal loads ,the adjustment of internal forces ,calculation of a combination of internal forces ,the vertical loads using D value method under horizontal loads ,internal forces calculated using the inflection point method in seeking the floor of the earthquake base shear method ,and then use the most unfavorable internal forces offframe structure of the reinforcement calcultoin section design of the beams according to the strong column and weak baem strong shear wear bending the principle of the weak component of the strong nodes of the internal force adjustment also contains the calculation of the number of components,such as panels and stairs.
Keyword:load;framework;structure design;internal forces;reinforcement
建筑面积:5830m2
建筑层数:6层
建筑高度:24.00m
