建筑面积:5847m2
建筑层数:6层
建筑高度:17.00m
文件内容:计算书+图纸+建模
【摘要】本次毕业设计的任务是完成厦门某六层A型洋房结构设计。场地类别为三类,抗震等级为三级,为现浇钢筋混凝土框架结构。
本次毕业设计的主要内容为结构设计。根据导师提供的建筑方案,进行结构设计,采用PKPM结构软件进行设计。根据地质勘察报告建议,基础采用独立基础。首先进入PMCAD菜单对结构建模,然后用SATWE得出结构分析的结果,其中荷载组合时考虑了恒载、活载、地震作用及风荷载等等。本工程选择了有代表性的一榀框架进行计算(○9轴框架)。对于竖向荷载作用采用分层法计算,水平荷载作用采用D值法计算。最后采用平法绘施工图,用AUTOCAD出图。
通过结构设计,熟悉了结构设计的全过程,掌握了结构设计软件使用方法,掌握了结构施工图的识图和绘制结构施工图的方法。
关键词 结构设计,荷载计算,内力计算,截面设计
【Abstract】This graduation project mainly talks about the structural design and analysis for a six-storey bungalow. Selected ground is subject to the third workable style. The grade of anti-earthquake is third level. The building is a structure of cast-in-place reinforced concrete frame system.
Based on the blue print my teacher provided, the design is structure design. This project uses the software of PKPM in designing. According to the result of the geological examination, the foundation will adopt the isolated foundation. First enter into PMCAD and input scale and size for estimating its feasibility including disposition of girders. Then apply SATWE to get results of structural calculation. In this process, anti-earthquake level, wind power, compounding load and so on were taken into account. This project has chosen a representative frame to calculate. Vertical load function adopts moment distribution method; level load function adopts D value method. In the end, construction drawings in different processes would be done and printed in AUTOCAD.
Through the designing, a good knowledge of the process of structural design have been commanded and learned how to use the structure designing software. Apart from these, a better understanding of the construction blueprint and the skills for drawing it has been gained.
【Key Words】 Structural design, Loads computation, Structural computation, Building structural design.
文件名:厦门某6层A型洋房框架结构设计(计算书 图纸)[面积5847].rar
