[建筑结构设计文档] 五层学生公寓建筑结构毕业设计计算书
  本设计为某一五层学生公寓的设计,主要包括建筑设计和结构设计两个部分。
  该公寓高18.9m,总建筑面积为2866m2,耐火等级为二级,抗震设防烈度为6度。建筑设计的内容包括平面、立面及剖面设计。
  结构设计包括框架设计、构件设计和基础设计等。其中,框架采用钢筋混凝土横向框架承重布置方案,基础采用钢筋混凝土柱下独立基础。本文着重对1榀横向框架进行了配筋设计。在确定了框架布局与分配统计得到各种荷载、作用的大小之后,按D值法、分层法及底部剪力法等弹性分析方法计算得出结构内力,并在此基础上,根据最不利原则进行内力组合,最后得到配筋成果。此外,本文还采用了PKPM软件进行设计,得出了结构施工图。
  【关键词】 框架结构、建筑设计、结构设计
  This design for some 15 student apartment design., mainly includes the architectural design and the structural design two parts.
  This apartment high 18.9m, the total floor space is 2866m2, the fireproof rank is two levels, the earthquake resistance fortification intensity is 6 degrees.Architectural design content including plane, vertical surface and section plane design.
  Structural design including frame design, component design and foundation design and so on.Among them, the frame uses the reinforced concrete crosswise frame load-bearing scheme of arrangement, the foundation uses under the reinforced concrete column the independent foundation.This article carried on emphatically to 1 pin crosswise frame has matched the muscle design.After had determined the frame layout and the assignment statistics obtain each kind of load, the function size, according to the D value law, the delamination and the base shearing force law isoelasticity analysis method computation obtains the structure endogenic force, and in this foundation, carries on the endogenic force combination according to the most disadvantageous principle, finally obtains matches the muscle achievement.In addition, this article also used the PKPM software to carry on the design, has obtained the structure construction drawing.
  [Key word] Portal frame construction, architectural design, structural design
  目   录
  摘要I
  第1章 绪论1
  1.1选题意义1
  1.2工程概况1
  1.3设计内容和方法1
  1.3.1设计内容1
  1.3.2设计方法2
  第2章 建筑设计说明3
  2.1建筑平面设计3
  2.1.1房间平面设计3
  2.1.2 楼梯设计4
  2.2建筑立面设计4
  2.2.1立面处理4
  2.2.2色彩处理5
  2.3建筑剖面设计5
  2.4建筑细部设计5
  第3章 结构设计说明7
  3.1框架承重方案7
  3.2梁柱截面尺寸估算7
  3.3结构计算简图7
  3.4结构计算内容8
  第4章 结构布置9
  第5章 重力荷载计算11
  5.1恒荷载计算11
  5.2活荷载计算13
  第6章 横向框架侧移刚度计算14
  6.1框架线刚度计算14
  6.2柱侧移刚度计算14
  第7章 横向风荷载作用下框架内力和侧移计算16
  7.1风荷载作用下标准值计算16
  7.2风荷载作用下水平位移计算17
  7.3风荷载作用下内力计算18
  第8章 竖向荷载作用下框架内力计算22
  8.1荷载计算22
  8.1.1恒载计算22
  8.1.2活荷计算23
  8.2弯矩计算24
  8.2.1恒荷作用下弯矩计算24
  8.2.2活荷作用下弯矩计算25
  8.3内力计算26
  8.4梁端剪力及柱轴力计算26
  8.4.1恒载作用下柱剪力及轴力计算31
  8.4.2活载作用下柱剪力及轴力计算33
  第9章 横向框架内力组合35
  9.1框架梁内力组合35
  9.2框架柱内力组合37
  第10章 截面设计42
  10.1框架梁设计42
  10.1.1梁正截面受弯承载力计算42
  10.1.2梁斜截面受剪承载力计算43
  10.2框架柱设计45
  10.2.1柱剪跨比和轴压比验算45
  10.2.2柱正截面承载力计算45
  10.2.3柱斜截面受剪承载力计算47
  第11章 构件设计48
  11.1楼梯设计48
  11.1.1梯段板设计48
  11.1.2平台板设计49
  11.1.3平台梁设计50
  11.2楼面板设计51
  11.3屋面板设计54
  第12章 基础设计58
  12.1基础尺寸确定58
  12.2软弱下卧层验算59
  12.3截面及配筋计算59
  设计心得62
  致谢64
  参考文献错误!未定义书签。
  第1章 绪论
  1.1选题意义
  本工程为哈尔滨市某学生公寓。由于原来的学生公寓已使用多年,条件与设备远达不到人们的标准,为提高学生的生后质量,改善其生活环境,决定兴建的新型学生公寓,以此来满足人们日常工作的需要。
  1.2工程概况
  本工程为钢筋混凝土框架结构,总建筑面积2866m2,设计使用年限为50年。本建筑按6度抗震设防,防火等级为二级。
  哈市地区基本雪压So=0.45kN/m2,基本风压wo=0.55kN/m2,地面粗糙度为B类。地势较平坦,地表下土层分布较不均匀,分为四层:第一层0.8m杂填土;第二层0.8-1.8m粉土层,地基承载力160kPa;第三层1.8-4.3m粘土层,地基承载力210kPa;第四层为淤泥质黏土,地基承载力特征值为95 kPa。冬季室外平均最低气温-26℃,全年主导风向为东南风。地下静止水位距室外地面8.0m,水质对建筑物无腐蚀作用,冬季土壤冰冻深度为2m。
Current Value 9510
Update Date 2016-12-15
