两跨钢筋混凝土排架厂房结构施工图设计
摘 要:单层厂房指层数仅为一层的工业厂房,适用于生产工艺流程有大型起重运输设备及较大动荷载的厂房,如冶金工业和其他工业等。单层厂房的核心结构,由支撑各种竖向的与水平的荷载作用的构件所组成。厂房依靠各种结构构件合理组成一个完整的结构空间以保证厂房的坚固、耐久。我国广泛采用钢筋混凝土排架结构和钢架结构,通常由横向排架、纵向联系构件、支撑系统构件和围护结构等几部分组成。单层砖柱厂房具有选价低廉、施工方便等优点,在中小型工业厂肩中得到广泛应用,如何进行有效的荷载效应组合、选取最不利内力组合,作为柱及基础的设计依据,将是本文要重点解决的问题。
关键词:内力组合;偏心受压;钢筋;混凝土
Frame Building Construction Design Of Two SpanReinforced Concrete Row Of An Enterprise
Abstract:Single-layer workshop refers to the layer number is only a layer of industrial workshop, applicable to the production process has a large lifting transport equipment and larger dynamic load of the plant, such as metallurgical industry and other industries. The core of the single-layer workshop structure, by the support of all kinds of vertical and horizontal loads of artifacts. Reasonable factory rely on a variety of structural components of a complete structure of space to ensure plant strong and durable. Widely used in reinforced concrete bent frame structure and steel structure in China, usually supported by transverse bent, vertical integration components, system components and retaining structure, etc.Single column brick factory has the advantages of selected price cheap, construction is convenient, is widely used in the small and medium-sized industrial factory shoulder, How to carry out the effective combination of action effects, select the most adverse internal force combination, as the pillar and foundation design basis, would be a focus in this paper to solve the problem.
Key words:Internal Force Combination; Eccentric Compression; Reinforced; Concrete
某企业两跨钢筋混凝土排架厂房结构施工图设计1
Frame Building Construction Design Of Two SpanReinforced Concrete Row Of An Enterprise2
1 引 言3
2 设计资料4
2.1设计题目4
2.2设计内容4
2.3设计依据4
2.4设计资料4
3 结构选型6
4 荷载计算7
4.1 恒载7
4.2 屋面活荷载7
5 施工部署9
5.1 施工目标9
5.2 施工顺序9
5.2.1 土建施工总体安排9
5.2.2 安装施工总体安排9
6 施工进度计划11
6.1 施工工期安排11
6.2 施工进度保证措施11
7 施工准备13
7.1 技术准备13
7.2 建筑材料的准备13
7.3 劳动组织准备13
7.4 施工现场准备13
8 资源配置计划15
8.1 施工劳动力配置15
8.2 施工材料供应15
8.3 施工资金准备15
9 分部分项工程施工方案16
9.1 施工测量16
9.1.1 主要测量人员及器具16
9.1.2 设立施工平面控制网16
9.1.3 主轴线的定位与放线16
9.1.4 高程控制16
9.1.5 沉降观测17
9.2 土方工程17
9.2.1 土方开挖17
9.2.2 楼基础底板模板17
9.2.3 桩基工程17
9.3 钢筋工程18
9.3.1 钢筋供应18
9.3.2 钢筋翻样18
9.3.3 钢筋绑扎18
9.4 模板工程18
9.4.1 模板的安装18
9.4.2 模板的拆除19
9.5 混凝土工程19
9.5.1 底板混凝土19
9.5.2 楼板混凝土施工19
9.5.3 施工缝的留置要求19
9.5.4 混凝土的养护19
9.6 砌筑工程20
9.6.1 砌筑材料20
9.6.2 施工工艺顺序20
9.6.3 施工准备20
9.7 脚手架工程20
9.7.1 脚手架的搭设和拆除20
9.7.2 脚手架的防护21
9.7.3 脚手架的验收21
9.8 防水工程21
9.9 楼地面工程21
9.9.1 水泥砂浆楼地面21
9.9.2 地砖楼地面22
9.10 装饰工程22
9.10.1 天棚抹灰施工22
9.10.2 内、外墙面抹灰22
9.10.3 外墙涂料施工23
9.10.4 门窗安装23
10 工程质量保证措施24
10.1 工程质量总目标24
10.2 质量保证体系24
10.2.1 组织机构24
10.2.2 质量管理职责24
10.3 质量保证措施25
10.4 成品保护措施25
11 施工安全、文明、卫生管理措施27
11.1 防火措施27
11.2 文明施工与环境保护措施27
11.2.1 文明施工措施27
11.2.2 环境保护措施28
12 施工项目季节性施工措施29
12.1 雨季施工技术29
12.2 夏季施工技术29
12.3 冬季施工技术30
13 施工现场平面布置31
谢 辞33
参 考 文 献34
1 引 言
厂房排架柱的定位轴线,在平面上构成的网络称为柱网。柱网布置就是确定纵向轴线之间的尺寸(跨度)和横向定位轴向之间的尺寸(柱距)。柱网布置既是确定柱的位置,也是确定屋面板、屋架和吊车梁等构件尺寸(跨度)的依据,并涉及结构构件和门窗洞的布置;柱截面的大小将直接影响厂房内部起重机的正常使用。故柱网布置和柱截面设计恰当与否将对厂房有着决定性的影响。柱网布置和柱截面选取的原则一般为:符合生产和使用的要求;建筑平面和结构方案的经济合理;在厂房结构形式和施工方法上具有先进性和合理性;符合厂房建筑模数协调标准的有关规定;适应生产技术和技术革新的要求
2 设计资料
2.1设计题目
2.2设计内容
(1)计算排架所受的各项荷载。
(2)计算各种荷载作用下的排架内力(对于吊车荷载不考虑厂房的空间作用)
(3)柱及牛腿设计,柱下单独基础设计。
(4)绘施工图:屋架、屋面板、屋盖支撑、吊车梁、柱及柱间支撑、墙体布置、基础平面布置及配筋图、柱模板图及配筋图。
2.3设计依据
(1)建筑结构荷载规范(GB50009-2001)
(2)混凝土结构设计规范(GB50010-2002)
(3)建筑地基基础设计规范(GB50007-2002)
(4)房屋建筑制图统一标准(GB/T5001-2001)
(5)建筑结构制图标准(GB/T50105-2001)
(6)各标准图集
(7)有关规范、标准、设计手册及教材
2.4设计资料
该厂房位于蚌埠高新区内,土地类别为Ⅱ类,该市基本风压为0.35KN/m2。基本雪压为0.3KN/m2,承载力标准值为240 KN/m2。
设计基准期为50年,抗震设防为6度,设计基本地震加速度为0.05g,抗震等级为四级,为丙类建筑。
地下水位较深,可不考虑。
厂房为两跨等高,跨度为18m,钢窗宽度2.4m,长度54m,柱距6m,室内地坪标高为0.000m,室外地坪为-0.150m,每跨设有10t吊车各2台,吊车工作级别为A5级,轨顶标高为7.8m,柱顶标高9.6m;
文件名:两跨钢筋混凝土排架厂房结构施工图毕业设计.rar
