Concrete structure reinforcement design
SheyanboⅠ WangchenjiaⅡ
Ⅰ Foundation Engineering Co., Ltd. Heilongjiang Dongyu
Ⅱ Heilongjiang Province, East Building Foundation Engineering Co., Ltd. Coal
Abstract:structure in the long-term natural environment and under the use environment's function, its function is weaken inevitably gradually, our structural engineering's duty not just must finish the building earlier period the project work, but must be able the science appraisal structure damage objective law and the degree, and adopts the effective method guarantee structure the security use, that the structure reinforcement will become an important work. What may foresee will be the 21st century, the human building also by the concrete structure, the steel structure, the bricking-up structure and so on primarily, the present stage I will think us in the structure reinforcement this aspect research should also take this as the main breakthrough direction.
Key word: Concrete structure reinforcement bricking-up structure reinforcement steel structure reinforcement
混凝土结构配筋设计
SheyanboⅡⅠWangchenjia
Ⅰ基础工程有限公司黑龙江东宇
Ⅱ黑龙江省东建筑地基基础工程有限公司煤
摘要:在长期的自然的环境下使用环境的功能结构,其功能减弱不可避免地渐渐地,我们的结构工程的责任不只是必须完成建设前期项目工作,但必须能够科学评价结构的破坏目标法律和程度,并采用有效的方法保证结构的安全使用,该结构加固将成为一个重要的工作。什么可以预见将是21世纪,人类建筑的混凝土结构,钢结构,砌体式结构等为主另外,现阶段我会觉得在结构加固我们这方面的研究也应借此作为主要的突破方向。
关键词:混凝土结构加固 砌体式结构 钢筋结构加固 |
