Building construction concrete crack of% g8 P- k$ {% ^2 c
prevention and processing
8 {) \; k9 K1 Y8 n Abstract
- S8 ]- H# r; _! D5 r2 }5 O% V! D The crack problem of concrete is a widespread existence but again difficult in solve of engineering actual problem, this text carried on a study analysis to a little bit familiar crack problem in the concrete engineering, and aim at concrete the circumstance put forward some prevention, processing measure.8 ?$ l8 q8 V9 ~3 p" d4 ~! V, ~
Keyword:Concrete crack prevention processing
$ F S. d* B$ G! M7 T& g7 D Foreword
9 B, V( P( H! [. D/ O, s Concrete's ising 1 kind is anticipate by the freestone bone, cement, water and other mixture but formation of the in addition material of quality brittleness not and all material.Because the concrete construction transform with oneself, control etc. a series problem, harden model of in the concrete existence numerous tiny hole, spirit cave and tiny crack, is exactly because these beginning start blemish of existence just make the concrete present one some not and all the characteristic of quality.The tiny crack is a kind of harmless crack and accept concrete heavy, defend Shen and a little bit other use function not a creation to endanger.But after the concrete be subjected to lotus carry, difference in temperature etc. function, tiny crack would continuously of expand with connect, end formation we can see without the aid of instruments of macro view the crack be also the crack that the concrete often say in the engineering.
- @/ W8 W/ `) X4 o; c! d" _6 Q8 o4 \/ q% K 建筑施工混凝土裂缝的预防与处理
4 S$ |$ d% Q& S k! r h5 d3 T$ O 混凝土的裂缝问题是一个普遍存在而又难于解决的工程实际问题,本文对混凝土工程中常见的一些裂缝问题进行了探讨分析,并针对具体情况提出了一些预防、处理措施。1 p* l7 D" ?5 @8 F4 t# w
关键词:混凝土 裂缝 预防 处理
; b+ {& T% P6 G- i( V1 ` 前言
1 L" q( l9 V8 _2 z, f 混凝土是一种由砂石骨料、水泥、水及其他外加材料混合而形成的非均质脆性材料。由于混凝土施工和本身变形、约束等一系列问题,硬化成型的混凝土中存在着众多的微孔隙、气穴和微裂缝,正是由于这些初始缺陷的存在才使混凝土呈现出一些非均质的特性。微裂缝通常是一种无害裂缝,对混凝土的承重、防渗及其他一些使用功能不产生危害。但是在混凝土受到荷载、温差等作用之后,微裂缝就会不断的扩展和连通,最终形成我们肉眼可见的宏观裂缝,也就是混凝土工程中常说的裂缝。 * n9 \5 p* E' c) }! ~+ N4 c
试读已经结束,如果需要阅读全文,请下载本文档 |
