Development and analysis of the large-span FRPwoven web structure
ABSTRACT: An innovative large-span structural system, namely the FRP woven web structure (FRPWWS), is introduced in this paper. In an FRPWWS, the high-strength FRP strips are “woven” like bamboo strips in a Chinese bamboo mat to form a plane web. The outer edge of the web is anchored on an outer ring beam, and an inner ring beam is provided to anchor the FRP strips at the center of the web. The stiffness of the web to resist various loads is derived from the initial prestressing during the “weaving” stage and the additional tensioning as a result of the out-of-plane movement of the inner ring beam. As a result of the high strength-to weight ratio of FRP, this new structural form offers an attractive option for the construction of spatial structures with spans longer than are possible with conventional structural materials. In this paper, the basic layout and construction procedure for a simple FRPWWS is first presented. Three basic weaving patterns are next explained. Several variations of the basic structural system are also proposed. A simple mechanical model is presented for the deformation of individual FRP strips. Results from a finite element analysis of an example structure are also given. The results of these analyses confirm the feasibility of the FRPWWS.
大跨度FRP网架结构的展望和分析
摘要:本文将会介绍一种新的大跨度结构,FRP织网结构。在一个FRPWWS结构中,高强度的FRP材料条像中国竹席中的竹片一样被编织在一起形成一个平面网,这个网状结构的外围锚固在一个圈形的梁上,结构的中心处还有一个用于锚固织网的内圈梁。织网结构靠编织生产时的初步预施加应力和内圈梁面外运动引起的附加张力调整来抵抗遇到的各类荷载。由于FRP材料的具有较高的材料-重量比,这种全新的结构形式为一些大跨度的空间建设提供了一种具有吸引力的选择方案,该跨度长于用常规结构材料建筑的跨度。在本文中,首先介绍了简单的FRPWWS结构的基本布局和施工步骤,接着阐明了三种基本的织造结构,同时也提出了此类结构方式的几种变化。文中介绍了一个简单的力学模型用于单个的FRP条力学变形,也给出了一个实例结构的有限元分析的过程。
