本设计为高速公路设计,设计部分的公路全长3589m,设计车速100km/h,双向四车道,设置中央分隔带。共设有2个平曲线,在所有圆曲线处均设缓和曲线。第一个弯道设有缓和曲线,缓和曲线长度240米,圆曲线半径800米。第二个弯道也设有缓和曲线,长度为280米,圆曲线半径800米。根据规范,圆曲线只设超高不设加宽。整个路段共设有四个竖曲线,竖曲线半径均设为18000米,并且满足了平纵面线形组合设计中的要求。路拱采用双向坡面,坡度值采用2%。在横断面的设计中,确定了横断面组成及各种要素后,绘制横断面图。路基设计的基本内容,就是确定路基边坡的形状和坡度。在挡土墙设计中满足了各种稳定性的验算。路面设计内容中包括路面类型与结构设计,路段路面设定两种方案,分别为沥青路面以及水泥混凝土路面。关键词:高速公路 山岭重丘 沥青路面 水泥混凝土路面
This is designed to high-speed highway design,Design part of the total length of highways 3589 m, the design speed 100 km / h,four-lane two-way,set Medium Divider. There are two-curve,in all round There will be a relaxation of the curve. The first corner with ease curve,easing curve length of 240 meters, round curve radius of 800 meters. The second corner is also a transition curve,a length of 280 meters,round curve radius of 800 meters. According to norms, with a round of a super-high not only for widening. There are entire sections of four vertical curve. There will be a radius of vertical curve for the 18,000 meters,and meet the vertical surface-linear combination of design requirements. Slope used two-way road humps,a gradient of 2 percent. In cross-section of the design,composition and determine the various elements of cross-sectional,drawing cross-sections. Roadbed design elements that determine the shape and slope roadbed slope. In the design of retaining walls to meet a variety of stability of checking. Design elements include road surface types and structural design,set up two sections of the road programme,namely the asphalt pavement and cement concrete pavement.Key words: Highway Mountain-Hill Asphalt Pavement Concrete Pavement
