资料简介: Response of a reinforced concrete infilled-frame structure to removal of two adjacent columnsMehrdad Sasani,Northeastern University, 400 Snell Engineering Center, Boston, MA 02115, United StatesReceived 27 June 2007; received in revised form 26 December 2007; accepted 24 January 2008Available online 19 March 2008
Abstract,The response of Hotel San Diego, a six-story reinforced concrete infilled-frame structure, is evaluated following the simultaneous removal of two adjacent exterior columns. Analytical models of the structure using the Finite Element Method as well as the Applied Element Method are used to calculate global and local deformations. The analytical results show good agreement with experimental data. The structure resisted progressive collapse with a measured maximum vertical displacement of only one quarter of an inch (6.4 mm). Deformation propagation over the height of the structure and the dynamic load redistribution following the column removal are experimentally and analytically evaluated and described. The difference between axial and flexural wave propagations is discussed. Three-dimensional Vierendeel (frame) action of the transverse and longitudinal frames with the participation of infill walls is identified as the major mechanism for redistribution of loads in the structure. The effects of two potential brittle modes of failure (fracture of beam sections without tensile reinforcement and reinforcing bar pull out) are described. The response of the structure due to additional gravity loads and in the absence of infill walls is analytically evaluated.c 2008 Elsevier Ltd. All rights reserved.Keywords: Progressive collapse; Load redistribution; Load resistance; Dynamic response; Nonlinear analysis; Brittle failure
钢筋混凝土填充框架结构对拆除两个相邻的柱的响应作者:Mehrdad Sasani 美国波士顿东北大学,斯奈尔400设计中心 MA02115收稿日期:2007年7月27日,修整后收稿日期2007年12月26日,录用日期2008年1月24日,网上上传日期2008年3月19日。
摘要:本文是评价圣地亚哥旅馆对同时拆除两根相邻的外柱的响应问题,圣地亚哥旅馆是个6层钢筋混凝土填充框架结构。结构的分析模型应用了有限元法和以此为基础的分析模型来计算结构的整体和局部变形。分析结果跟实验结果非常吻合。当测量的竖向位移增加到为四分之一英寸(即6.4mm)的时候,结构就发生连续倒塌。通过实验分析方法评价和讨论随着柱的移除而产生的变形沿着结构高度上的发展和荷载动态重分配。讨论了轴向和弯曲的变形传播的不同。结构横向和纵向的三维桁架在填充墙的参与下被认为是荷载重分配的主要构件。讨论了两种潜在的脆性破坏模型(没有拉力加强的梁的脆断和有加筋肋的梁的挤出)。分析评价了结构对额外的重力和无填充墙时的响应。关键词:连续倒塌;荷载重分配;对荷载抵抗能力;动态响应;非线性分析;脆性破坏。
