本次毕业设计是教学楼设计包括建筑设计和结构设计两部分内容。建筑设计是在总体规划的前提下,根据设计任务的要求,综合考虑基地环境、使用功能、综合选型、施工、材料、建筑设备、建筑艺术及经济等。着重解决了建筑物与周围环境、建筑物与各细部构造,最终确定设计方案,画出建筑施工图。结构设计是在建筑物初步设计的基础上确定结构方案;选择的结构体系;进行结构布置,并初步估算,确定结构构件尺寸,进行结构计算。结构计算包括荷载计算,变形计算,内力分析及截面设计,并绘制相关的结构图和施工图。
关键词
框架结构;内力组合;地震
The desgin is a scheme of a teaching building,it includes two parts-architecture design structure design.
In the architecture design and structure designing the architecture design ,I compressively consider the base avement using faction ,structure type,construction building materials equipment architecture economy and architecture economy and architecture art act .Then I mainly solve using space in the building and coordination between inside and outside conditions. In the structure design,determine in the structure design based on architecture first design. Select the right structure type.
Precede structure arrangement and sizes of structure and of structure components to calculate.All work about calculation including load estimation deform test. Mechanics analysis and selection design,In the end ,drawing all the blueprints of architecture construction and structure constructor.
Keywords
Load combinations;Section design;Earthquake |
