素混凝土的尺寸效应及动态响应
  Size Effects and the Dynamic Response of Plain Concrete
. n* Z# v4 C/ m8 o3 t; N' K  V. Bindiganavile 1 and N. Banthia 2
4 O- E+ K' x' S5 H  Abstract: This paper investigates the specimen size effect on the dynamic response of plain concrete. The report is based upon8 \0 }: L& _# i1 Q% W
  experimental data by the writers and others and considers results from creep tests on beams, beams under flexural impact, and cylinders2 ?% R$ i; D2 I3 v" a
  under axial impact loading. Size effect is examined using Ba?ant’s size effect law and the multifractal scaling law, and both scaling models
$ F4 q; p6 Y1 t9 r  are able to capture the size effect on strength. For fracture energy, on the other hand, the size effect manifests itself only at impact rates.
' w4 F% x2 Y& d2 P  Under quasi-static loading, plain concrete in compression is less sensitive to the specimen size. But under impact, the compressive
" Y, n# e- J6 r4 s  response appears to be more size dependent than flexure. However, upon accounting for the stress rate effects, the flexural response! O- V& W* i8 k; K3 q  Y4 T1 j
  depicts a more significant size effect, similar to that seen at quasi-static rates.
' P& r& B$ O" m3 g. h  DOI: 10.1061/_ASCE_0899-1561_2006_18:4_485_
3 Q, A8 P/ p, T; [$ }  CE Database subject headings: Fracture; Concrete; Size effect; Dynamic response7 H, e2 ~* @- V* J: ~) [
  素混凝土的尺寸效应及动态响应  y6 ~% O+ t: u6 X
  摘要:本文研究了素混凝土试样动力响应的尺寸效应。该报告是根据作者和其他人的实验数据并考虑了梁的蠕变、弯曲影响下的梁和受轴向冲击载荷作用的圆柱体的试验结果。尺寸效应是通过使用Bazant的规模效应法和多重标法则来监测的,而且缩放模式能够捕捉尺寸效应的强度。对于断裂能,换言之,规模效应仅仅体现在影响率上。在准静态荷载作用下,受压素混凝土对试件尺寸更加不敏感。但是在冲击作用下,压缩反应相对于弯曲作用似乎更依赖尺寸。然而,考虑到应力变化率的影响,弯曲响应描绘了更加重要的尺寸效应,它类似于准静态荷载作用下的响应。% v7 a' p* B" B0 N, E' S& [
  DOI(数字对象唯一标识): 10.1061/_ASCE_0899-1561_2006_18:4_485_* t# b& O, ~  Q+ F+ f- j! r
  数据库主题词  土木工程数据库主题词:断裂;混凝土;尺寸效应;动态响应。
外文文献翻译-素混凝土的尺寸效应及动态响应(1)
外文文献翻译-素混凝土的尺寸效应及动态响应(2)
外文文献翻译-素混凝土的尺寸效应及动态响应(3)
外文文献翻译-素混凝土的尺寸效应及动态响应(4)
外文文献翻译-素混凝土的尺寸效应及动态响应(5)
外文文献翻译-素混凝土的尺寸效应及动态响应(6)
外文文献翻译-素混凝土的尺寸效应及动态响应(7)
外文文献翻译-素混凝土的尺寸效应及动态响应(8)
外文文献翻译-素混凝土的尺寸效应及动态响应(9)
外文文献翻译-素混凝土的尺寸效应及动态响应(10)
外文文献翻译-素混凝土的尺寸效应及动态响应(11)
外文文献翻译-素混凝土的尺寸效应及动态响应(12)
外文文献翻译-素混凝土的尺寸效应及动态响应(13)
外文文献翻译-素混凝土的尺寸效应及动态响应(14)
外文文献翻译-素混凝土的尺寸效应及动态响应(15)
外文文献翻译-素混凝土的尺寸效应及动态响应(16)
外文文献翻译-素混凝土的尺寸效应及动态响应(17)
外文文献翻译-素混凝土的尺寸效应及动态响应(18)
外文文献翻译-素混凝土的尺寸效应及动态响应(19)
外文文献翻译-素混凝土的尺寸效应及动态响应(20)
外文文献翻译-素混凝土的尺寸效应及动态响应(21)
外文文献翻译-素混凝土的尺寸效应及动态响应(22)
外文文献翻译-素混凝土的尺寸效应及动态响应(23)
Current Value 12535
Update Date 2017-10-31
