• 软件中心
  • 在线留言
  • 搜索
  • 公众号
    微信扫码快速关注
  • 土木工程毕业设计
    土木工程课程设计
    52毕设网
    三跨预应力连续箱梁桥毕业设计中英文摘要
    资料分类:土木工程毕业设计 - 中英文摘要 | 发布形式:资料共享 | 更新时间:2018-02-04 显示全部楼层
      摘  要
      连续梁桥是工程上广泛使用的一种桥型,它不但具有可靠的强度,刚度及抗裂性,而且具有行车舒适平稳,养护工作量小,设计及施工经验成熟的特点。设计一座梁桥必须从桥跨布设,尺寸拟定,钢束布置以及施工方法等方面综合考虑,还要充分考虑设计参数和环境影响。本设计是三联连续梁桥,横截面形式为四片单箱单室预制箱型梁,;施工方式是先简支后连续施工的连续梁桥。该设计首先进行恒载、活载及次内力的计算,在此基础上进行荷载组合,绘制弯矩和剪力包络图;其次,根据短期效应组合配置预应力钢筋,并进行预应力损失的计算;最后,对该连续梁桥进行验算,是否满足设计要求。
      关键词:设计  连续梁桥  先简支后连续  预应力
      The continuous beam bridge is a kind of bridge type used widely on the project. It not only has a reliable strength, stiffness and cracking, but also has a smooth journey comfortable, conservation work on the design and construction experience of the characteristics of maturity. Design a bridge must be laid across from the bridge-laying, the size of the development, steel beam layout and construction methods, but also give full consideration to the design parameters and environmental impact. This is a design for a three-span continuous bridge, whose cross-section is one-compartment, and no changing on the road direction, constructed by after a first simply-supported. The first design includes constant load, the live load and the calculation of the internal forces. On the basis of a load combination, we can draw moment and shear envelope map. Next, according to the short-term effect combination disposition prestressed reinforcement, and carries on the loss of prestress the computation. Finally, carries on the checking calculation to this continuous bridge, whether to satisfy the design requirements.
      Key Words: design; continuous bridge; after a first simply-supported; prestress
    关闭延时 道具 收藏一下
    全部评论 已有0条评论 发表评论
    中英文摘要
    编号 52S80504560
    最新资料
