资料简介: 摘要:普萨~阿卡孜达坂公路设计第二合同段进行道路工程、路基路面工程的施工图设计,同时进行桥梁和涵洞的总体布置图设计。
道路路线设计对路线进行了平面设计、纵断面设计,设计是从工程建设的经济性和合理性的出发,尽量采取少填挖,减少工程量。同时也要考虑路线要与周围的自然景观相协调。
道路路基路面设计主要对道路的横断面和路面的结构层进行设计和计算。道路横断面根据设计车速、交通量要求进行设计,同时考虑了边坡的坡率取值。路面的结构层牵涉到路面材料的选取和材料强度、刚度和稳定性的验算。考虑到沥青价格昂贵,所以本段路采用混凝土路面。
桥涵设计要求在施工的使用过程中应具有足够的强度、刚度和稳定性。根据地形要求本段路设置了4个涵洞和一座跨径50米的连续梁桥,其中圆管涵2个,板涵2个。
本设计在制图方面严格按照中华人民共和国国家标准《道路工程制图标准》(GB 50162-92)进行,采用AutoCAD制图。
【关键词】 高速公路 横断面图 路基设计 路面设计 线形设计 施工图设计
Abstract :Pu Sa the ~ Aka unwearied effort reaches ban the highway design second contract section to carry on the road engineering, the roadbed road surface project construction drawing design, simultaneously carries on the bridge and the culvert general layout design. the path location has carried on the plane design, the longitudinal section design to the route, the design is from engineering construction's efficiency and rational embarking, adopts as far as possible little fills in digs, reduces the resilience. Simultaneously must consider that the route must be coordinated with the periphery natural landscape. the path roadbed pavement design mainly carries on the design and the computation to path's cross section and the road surface structure level. The cross-section of road according to the design vehicle speed, the volume of traffic requests to carry on the design, simultaneously has considered the side slope ratio of slope value. The road surface structure level involves to the road surface material selection and the material strength, the rigidity and the stable checking calculation. Considered the asphalt price is expensive, therefore this section of roads use the coagulation earthen road pavement. the arch of bridge design requirements should have the enough intensity, the rigidity and the stability in the construction use process. Requested this section of roads according to the terrain to establish 4 culverts and a span 50 meter continuous bridge, the circular pipe contained 2, the board contained 2. this design strictly "Road engineering Charting Standard" (GB 50162-92) carries on the charting aspect according to the People's Republic of China national standards, uses the AutoCAD charting.
Key words: cross-sections highway roadbed design linear design of the road design and construction design plans
