某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662]
建筑面积:4662m2
建筑层数:6层
建筑高度:22.50m
文件内容:计算书+图纸+任务书+开题报告
摘  要
本结构为商业住宅,采用钢筋混凝土框架结构,抗震等级为二级,抗震设防烈度为7度,整个设计包括建筑设计和结构设计两部分。
建筑设计部分,首先根据建筑的使用功能确定建筑的初步布局,包括建筑体型及室内空间布置,然后确定具体尺寸和平、立面风格等。
结构设计部分,首先根据建筑设计、工艺使用要求、材料供应情况及场地地质条件等确定结构布置方案,然后选取一榀典型框架进行设计计算。在明确计算简图的前提下,进一步确定框架承受的荷载,包括恒载、屋(楼)面活载和风荷载,在此基础上进行框架内力计算、内力组合、梁、柱和基础等构件的配筋计算。除此之外,还进行了屋(楼)面板、楼梯等附属构件的设计计算。
在上述工作的基础上,制图软件Auto CAD 2007绘制了建筑施工图和结构施工图。
关键词:钢筋混凝土框架结构;建筑设计;结构设计
This structure for commercial housing, using reinforced concrete frame structure, the seismic grade for the second, seismic fortification intensity for 7 degrees, the whole design including building design and structure design two parts.
Architecture design part, first of all, according to the use function of building the preliminary layout determined architecture, including the body shape and interior space layout, and then determine the detailed dimension peace, facade style, etc.
Part of the structure design, architectural design, process first according to use a requirement, material supply and the geological condition, determine the structure arrangement plan, then select a hinged frame of typical design calculation. In the clear simple plan calculation, under the premise of further define the load carried framework, including constant load, house (floor) surface live load and wind load, and based on internal force calculation, internal force framework combination, beams and columns and foundation of the component such reinforcement calculation. In addition, but also for the house (floor) panel, stair subsidiary component design calculation.
In the above work, and on the basis of the drawing software Auto CAD 2007 mapped the building construction drawing and structure construction drawing.
Keywords: reinforced concrete frame structure; Architecture design; Structure design
工程概况
工程名称:沧州市某商业住宅楼设计方案一
工程地点:沧州市
工程信息:总建筑面积4662.3                              ,总层数为6层;一层为商店,层高为4.5 ,建筑面积约1600 ;二层以上为住宅,层高为3 ,二~六层单层建筑面积为597 ;顶层屋顶为上人屋面楼梯间建筑面积为28.8 。
结构形式:该工程采用钢筋混凝土框架结构。
建筑说明
拟建该建筑位于沧州市市内,为商用与住宅综合建筑,该建筑北面临街,商店主入口身在北边。该工程占地1591.8 ,建筑面积4662.3 。该工程拟建为六层,一层为商店,二~六层为住宅。
建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](1) 毕业设计.pdf (1.91 MB, 下载次数: 9)
建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](2) 建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](3) 建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](4) 建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](5)
建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](6) 建筑结构毕业设计-某6层商业住宅楼建筑结构设计(计算书+图纸)[面积4662](7)
Current Value 13410
Update Date 2015-10-29
