建筑面积:1236m2
建筑层数:4层
建筑高度:15.6m
文件内容:图纸+施工组织设计+工程量清单+工程量计价表+布置图+进度图
本次毕业设计的课题是“某基督教堂建筑楼施工组织设计及报价”,根据任务书要求,需要完成一份施工规划(技术标)及一份商务标,采用Excel,天正建筑,未来清单造价等专业软件编制。
技术标包括施工组织设计,施工进度表及施工平面布置图三项内容。本施工组织设计以设计文件为依据进行编写,编制时对目标工期、工程质量、项目管理机构设置、劳动力组织、施工场地的有效利用、施工进度计划控制、机械设备及周转材料配备、主要分部分项工程施工方法、安全保证措施、文明施工及环境保护措施、降低成本措施等诸多因素综合考虑分析,突出科学性及可行性,确保工程顺利进行。
商务标是根据建设工程工程量清单计价规范,江苏省建筑工程与装饰工程计价表,江苏省建筑与装饰工程费用计算规则等规范编制的投标报价,将作为投标中标的主要经济依据。主要包括地基处理工程、土方工程、基础工程、主体工程、装饰装修工程的工程量计算及报价。
关键词:施工组织设计 工程进度 施工平面布置 投标报价
The graduation design topic is "a Christian church building floor the construction organization design and quotation," according to requirements, need to perform a task of construction planning (technical standard) and a copy of the business standard, using Excel, TianZhengJianZhu, future cost as well as professional software of the list.
Technical standard including the construction organization design, construction schedule and construction layout three content. The construction organization design basis for design documents compiled to write, when target period, engineering quality, project management organization setup, labor organization, the effective use of construction sites, construction schedule control, mechanical equipment and turnover materials equipment, main divisions breakdown construction method, safety guarantee measures, civilized construction and environmental protection, cost reduction measures factors such as comprehensive consideration of the analysis, outstanding scientific and feasibility, ensure project smoothly.
According to the construction of the business standard is the valuation standard, jiangsu construction and decoration project in jiangsu province, architecture and priced table decoration engineering cost calculation rules, the specifications for bid price quotations will serve as the main economic basis bids bid. Mainly includes foundation treatment engineering, earth-moving, basic engineering, the principal part of the project quantity, decoration engineering calculation and quotations.
Keywords: The construction organization design Project progress
Construction layout Bid price quotation
本工程为四层(局部五层)框架结构,丙类建筑,耐火等级为二级,工程设计使用年限50年;抗震设防标准为7度,加速度值0.15g;屋面防水等级Ⅲ级;本工程长为28.5m,宽为11.9m,建筑面积约1236平方米,±0.00相对于建筑西侧某路中心线上提300mm,建筑物高度为15.6m,层高为3.9m(局部五层为3.9m)。防潮层的做法为防水砂浆防潮,地面为地砖地面,楼面为地砖楼面,内墙面刷乳胶漆,外墙面采用白水泥腻子亮度、乳白色水泥漆饰面和青灰色水泥饰面。屋面为高分子沥青卷材屋面,平顶为板底水泥砂浆平顶。基础为独立基础,基础混凝土为C30,垫层为C15素混凝土,柱子为C30混凝土,梁为C30混凝土,板为C30混凝土。混凝土使用商品砼。钢筋采用一、二、三级钢。内外填充墙均采用MU7.5砌块和M5混合砂浆砌筑。柱子尺寸有400mm*400mm和300mm*400mm。梁尺寸有200mm*300mm、200mm*600mm、300mm*600mm、200mm*500mm、250mm*750mm、300mm*750mm。板厚为100mm。 正文部分内容展示
施工组织设计.pdf
(302.09 KB, 下载次数: 27)
