设计总说明
本工程为某师范大学4号综合实验楼,主体结构采用现浇钢筋混凝土框架结构,总长度为74.7m,总宽度为18m, 总高度为22.05m,总建筑面积为8108m2,共六层,各层层高均为3.6米。
本毕业设计主要完成以下内容:
一、建筑设计
根据建筑的使用功能进行建筑的平面布置及建筑造型设计,并确定建筑材料及绘制建筑施工图。
二、结构设计
1.结构布置及结构计算简图;
2.确定梁、柱截面尺寸;
3.荷载计算,包括重力荷载、水平地震作用等;
4.荷载效应组合;
5.梁、柱配筋计算;
6.基础设计;
7.绘制结构施工图;
8.利用计算机程序进行结构分析。
三、招标文件制作
关键词:建筑设计,钢筋混凝土,框架结构,抗震设计,结构计算
General statement for design
This engineering is the No.4 multiple-use building of a Normal University,and the form of the base structure of this building is frame structure of cast-in-place concrete,with the total length of 74.7m,with the total wedth of 18m,with the total height of 22.05m,and with the total built-up area of 8108m2.The building has six stories and the height of each story is 3.6m.
The purpose of the graduation design including the following contents:
I. Architecture Design
according the building function to arrange the rooms of the building, determine the architectural style and the material of the building and draw the architectural working drawing.
II. Strcture Design
1. Determine the construction arrangement and the calculate concise picture.
2.Determine beam、column cross-section size.
3. Load calculate. Including gravity load、horizontal earthquake load and so on.
4. Load effect combination.
5. Calculate the required reinforcing bar of the beam and column.
6. Foundation design
7. Draw the working drawing of building structure.
8. Strcture analysis by computer program.
III. Draw up a public bidding documents of this engineering.
Key words: architecture design, reinforced concrete, frame structure, anti-seismic design, structure calculation |
