设计总说明
施工组织设计是建筑施工组织的核心和灵魂,是对工程建设项目全过程的构思设想和具体安排,用来指导施工项目全过程各项活动的技术、经济和组织的综合性文件。
本工程位于江门市开平市区,为民用住宅楼,主体为框架剪力墙结构,主楼为筏板基础;本工程地下一层,地上结构分8个单元区17层,建筑总高度56.2m,总建筑面积22411.81m2,本工程混凝土强度在C25到C40之间。本工程建筑类别二级 ,耐火等级二级 ;半地下室耐火等级一级,停车场类别为一类,抗震等级为7级,属高层住宅框支剪边墙结构。本施工组织设计是根据B1~B3栋住宅楼现场实际情况编制的。编制时对项目管理机构设置、施工总体部署、施工准备、主要分部分项工程施工方法、工程质量保证措施、安全及文明施工措施、施工现场管理措施等诸多因素尽可能充分考虑,突出科学性、适用性及针对性,是确保优质、低耗、安全、文明、高速完成全部施工任务的重要经济技术文件。
本设计主要包括以下内容:工程施工组织设计书、施工平面布置图。为确保工期、质量及安全、文明工地,节约成本等条件,编制出针对每个分部分项工程的特点、结构特征、施工难易程度工期和质量要求,编制出切实可行的施工方案。以指导施工顺利地完成本工程项目的建设,控制工程成本,创建优质工程。
General Description Of Design
The construction organization design is the core of construction organization and the soul, is the whole process of construction of the project design ideas and specific arrangement, used to guide the construction project activities of the whole process technology, economy and organization of comprehensive files.
This project is located in kaiping jiangmen city, for civilian residential building, subject to frame shear wall structure, the main building is a raft foundation; This engineering underground, the ground structure points eight unit area and layer, building a total height of 56.2 m, with a total construction area of 22411.81 m2, this project the strength of concrete in C25 to C40 between. This engineering construction category 2 class, fireproof grade level 2; Half the basement fireproof grade level, parking lot for a category, the seismic grade for level 7, belong to a high-rise residential box shear wall structure. The construction organization design is based on B1 ~ B3 storied dwelling buildings of the actual situation. Prepare to the project management institutions set when the overall arrangement, construction, construction preparation, main branch disciplines construction method, engineering quality assurance measures, safety and civilized construction measures, the construction management measures, and many other factors fully consider as far as possible, outstanding scientific, applicability and targeted, is to make sure the high quality, low cost, safety, civilization, the completion of all the important task of economic construction technical documents.
This design includes the following content: engineering construction design document and construction the floor plan. To ensure the quality and safety, construction period, civilized construction site, the cost savings and conditions, developed for each division of the sectional works characteristics, structure characteristics, easy of construction schedule and quality requirements, developed and feasible construction scheme. In order to guide the construction successfully complete the project construction, project cost control, create quality engineering. |
