资料简介: 摘要
单层厂房指层数仅为一层的工业厂房,适用于生产工艺流程有大型起重运输设备及较大动荷载的厂房,如冶金工业和其他工业等。单层厂房的核心结构,由支撑各种竖向的与水平的荷载作用的构件所组成。厂房依靠各种结构构件合理组成一个完整的结构空间以保证厂房的坚固、耐久。我国广泛采用钢筋混凝土排架结构和钢架结构,通常由横向排架、纵向联系构件、支撑系统构件和围护结构等几部分组成。
单层砖柱厂房具有选价低廉、施工方便等优点,在中小型工业厂肩中得到广泛应用,如何进行有效的荷载效应组合、选取最不利内力组合,作为柱及基础的设计依据,将是本文要重点解决的问题。
关键词:内力组合;偏心受压;钢筋;混凝土
Single-layer workshop refers to the layer number is only a layer of industrial workshop, applicable to the production process has a large lifting transport equipment and larger dynamic load of the plant, such as metallurgical industry and other industries. The core of the single-layer workshop structure, by the support of all kinds of vertical and horizontal loads of artifacts. Reasonable factory rely on a variety of structural components of a complete structure of space to ensure plant strong and durable. Widely used in reinforced concrete bent frame structure and steel structure in China, usually supported by transverse bent, vertical integration components, system components and retaining structure, etc.
Single column brick factory has the advantages of selected price cheap, construction is convenient, is widely used in the small and medium-sized industrial factory shoulder, How to carry out the effective combination of action effects, select the most adverse internal force combination, as the pillar and foundation design basis, would be a focus in this paper to solve the problem.
Keywords: internal force combination; Eccentric compression; Reinforced; concrete
