该建筑为综合办公楼,位于北京市区。地上总建筑面积41627平方米。建筑物主体高度88米,地上21层,地下1层。首层为大厅、大会议室等功能空间,二层为小会议室、机房等,三层、四层为办公室和餐厅及厨房,五层至二十一层均为办公功能空间。冷热源:工程采用区域热泵能源站供冷供热。空调水系统:采用双管制变水量系统。空调风系统:采用全空气空调系统和风机盘管加新风系统。通风设计:采用机械排风系统和机械补风系统。先对本工程进行工程项目结构分解,随后对水系统,风系统,系统调试等进行工程量的计算,工程预算紧随其后,然后确定施工方案,进行施工进度管理、技术管理、质量管理等。
关键词:全空气系统 风机盘管 结构分解 工程预算 施工方案 进度管理
The northern New District Management Committee Office building ventilation and air conditioning engineering construction organization design
The building is a comprehensive office building, located in downtown Beijing. A total construction floor area of41627 square meters. The main building is 88 meters high, on the ground 21, underground 1layer. The first layer is a hall, conference room and other functional space, the two layer is a small conference room, computer room, three layer, four layer for office and dining room and kitchen, the five layer to the twenty-one layer are office space. Cold and heat source: works by regional cooling and heating heat pump energy station. Air conditioning water system: using double control variable water flow system. Air conditioning system: adopt the whole air conditioning system and fan coil plus fresh air systems. Ventilation design: using a mechanical exhaust system and a mechanical ventilation system. On the construction project structure breakdown, then the water system, air system, system debugging, engineering, engineering budget followed, and then determine the construction scheme, construction schedule management, technology management, quality management.
Key words: full air system for fan coil structure decomposition of engineering budget plan of construction progress management
工程概况
该建筑为综合办公楼,位于北京市区。地上总建筑面积41627平方米。建筑物主体高度88米,地上21层,地下1层。首层为大厅、大会议室等功能空间,二层为小会议室、机房等,三层、四层为办公室和餐厅及厨房,五层至二十一层均为办公功能空间。本工程采用区域热泵能源站供冷供热,空调水系统采用双管制变水量系统,空调风系统:采用全空气空调系统和风机盘管加新风系统,通风设计机械防排烟系统。地下一层为小型机动车停车库及设备用房,划分为四个防火分区,其中两个为汽车库,一个为自行车库及一个设备用房,战时局部为二等人员掩蔽所,共划分为三个防护单元。
部分内容展示
03毕业设计说明书.pdf
(1.24 MB, 下载次数: 6)
