建筑面积:4109m2
建筑层数:5层
建筑高度:21m
文件内容:计算书+图纸+施工组织设计+电算
这次毕业设计题目是12班初级中学教学楼建筑框架设计,教学楼的纵向长度为45.9m,横向长度为16.8m。建筑总高度为21m,室内外高差为0.45m,基础采用柱下独立基础,总建筑面积为4109平方米。
设计包括计算书一份和图纸一份,施工组织设计几部分,图纸包括建筑施工图和结构施工图。选取一榀框架轴号⑥作为计算单元。
计算书包括以下几个主要部分:1荷载计算、梁、柱的尺寸确定,这一部分主要是要选对跨度尺寸,不要选纵向跨度来计算横梁的尺寸。2风荷载与地震作用的侧移验算,这一部分主要是计算准确,如风荷载以集中荷载的形式作用在每层节点上,再算每个节点的风作用的面积要准确,侧移是指整个建筑物在风荷载作用方向的位移。3风荷载与地震作用内力的计算,这部分主要采用D值法计算,这部分主要是反弯点的位置计算要准确,算出弯矩,画出弯矩图,再根据弯矩算出剪力,计算轴力。4恒荷载与风荷载的内力计算,这部分主要采用二次弯矩分配法来计算弯矩,再根据弯矩算出剪力,计算轴力。5内力组合,选出最不利组合。6根据最不利组合来进行梁柱板楼梯的配筋计算。7基础的配筋计算。建筑施工图是考虑地理环境、使用功能、施工简单、材料及经济等,综合选型,最终画出建筑施工图。
关键词:荷载,内力组合,计算配筋,建筑设计
The graduation project topic is 12 classrooms teaching building in the framework design, including calculations and drawings for a copy of two parts, Longitudinal length of the building is 45.9m, the lateral length of 16.8m.Total building height 21m, interior height is 0.45m, under the column basis using an independent basis, with a total construction area of 4109 square meters.
drawings including construction drawings and construction drawing.selecting axial ⑥ as compute element.
Calculations include the following major sections: a load calculation, beams, columns determine the size of this part is to choose the size of the span, do not choose to calculate the longitudinal span of the beam size.2 wind loads and seismic action sway checking, this part is accurate calculation of wind loads in the form of concentrated load acting on each node, and then calculate wind action area for each node to be accurate, lateral means.The whole building wind load displacement direction.3 internal force wind loads and seismic calculations, this part D values calculated using the method, which is the location of some of the major inflection point calculations to accurately calculate the moment, draw bending moment diagram, and then calculate the shear According moment,calculated axial force.Internal force calculation 4 dead load and wind load, which is part of the main quadratic assignment method to calculate the bending moment, and then calculate the shear According moment, calculated axial force.5 internal forces combined to select the most unfavorable combination.6 According to the most unfavorable combination to calculate beams reinforcement plate stairs.7-based reinforcement calculation.
Keywords:the load,the combination of internal force,calculation of reinforcement;architecture design .
毕业设计手算.pdf
(1.1 MB, 下载次数: 4)
