本施工组织设计依据国家现行相关设计规范、标准、建设方所提供的《湖南省隆回县农业局办公楼岩土工程勘察报告》、建设方提供的设计委托书、及城市规划管理局对本工程方案设计的审查意见通知书进行编制。本工程为湖南省隆回县农业局办公楼,六层框架结构,基础采用独立基础,设计使用年限主体结构50年,建筑高度为26.250m,建筑面积为5615m2。本工程级别为三级,耐火等级为二级。
通过合理安排施工顺序,充分利用机械设备,努力提高劳动效率。组织现场安全、文明施工及环境保护,从而确保工程的安全和质量。并协调施工过程中各施工单位、各施工工种、各项资源之间的相互关系。将会使其建筑施工项目活动协调有序,且能有效缩短施工工期、并降低成本。最终完成编制。
关键词:住宅楼 施工组织 施工方案 施工部署
Construction organization design is the construction condition of the project, according to the relevant engineering construction decisions, and set a technical document, guidance and organization construction measures. As a guide the construction process of the technical and economic activities of the programmatic document, is the construction technology and construction project management of the organic combination of product, it is after the commencement of construction activities can orderly, efficient, scientific and reasonable to guarantee.This works for Office Building. Seven story frame structure. Using an independent basis of foundation. The main structure design life of 50 years. Building height of 26.250 m. Construction area of 5615 m2. This project is a three-level. Fire resistance rating of two.
By reasonable arrangements for the construction sequence. Civil construction and environmental protection. In order to ensure the safety and quality of the project. The relationship between the construction process of coordination. Make coordinated construction project. Effectively shorten the construction period and reduce costs. Completion of construction design.
KEYWORD: Residential building;Construction Construction organization;The construction plan; Construction of the deployment |
