总建筑面积约为4400 m2,采用框架承重结构,主体结构层数为六层,首层层高为4.2m,其余均为3.3m,抗震设防烈度为7度。
本次设计分为建筑与结构设计两部分。本计算书包括了整个设计的计算过程及相关的明。
设计的成果除建筑设计说明,总平面图;首层平面图、标准层、顶层平面图,正立面图、侧立面图;剖面图;主外墙大样图,节点大样图外还应包括结构设计的计算:荷载汇集;地震作用计算;风荷载作用计算;荷载组合及内力分析;一榀框架配筋计算;现浇板配筋计算;楼梯配筋计算;悬挑构件计算;基础及基础梁配筋计算;报告厅部分结构设计计算;薄弱层验算;其它必要的构件配筋计算。
关键词:建筑设计 结构计算 结构布置 内力计算 配筋计算
The title of this thesis design is the apartment of XingZhi . Total construction area is about 4400 sq.m, frame structure, 6 floors. The height of all floor is 4.2m and 3.3m, the design strength of anti-earthquake is 7 degrees.
This design is divided into two parts: architectural design and structure design. This thesis includes all the calculations of the design process and related elucidations.
Among them, primarily there are the arrangement of structure, the selection of structure type, a complete calculation of one part of the frame (includes the calculation of load and force, combination of forces, design of section and calculation of reinforcement). Besides, there are design of column foundation, stairs, pored concrete slab and concrete awning etc.
Keywords: architectural design structure design the arrangement of structure the calculation of load and force the calculation of reinforcement
建筑面积:4400m2
建筑层数:6层
建筑高度:20.1m
李祥计算书宿舍.pdf
(1 MB, 下载次数: 1)
