杭州市二层金工工业厂房
本工程为二层框架式杭州市二层金工工业厂房,建筑面积4500m2,占地面积2250m2,二层,总高10m,采用框架式结构,柱下独立基础,设计基准期50年,结构安全等级为二级,抗震设防烈度为7度。建筑设计本着“功能适用,经济合理,造型美观,环境相宜”的原则,以国家相应规范、标准为依据,完成了设计任务书所要求的建筑平面设计,并在此基础上进行了立面、剖面、建筑详图设计,共画出建筑图张。结构设计本着“安全,适用,耐久”的原则,进行了竖向荷载汇集,水平荷载汇集,内力计算,内力组合,结构抗震验算,板、梁、柱、楼梯、基础等结构构件的设计。
关键词:框架式杭州市二层金工工业厂房 框架结构 柱下独立基
A c building design
This is a design for mall building of a city. Its building area is4500m2 and it will cover a field of 2250m2. It is a four-storied building with 10-meters high structure and single footing are used for this building. The design working life is 50 years, and the safety class is 2. The seismic fortification intensity is 7. On the principle of “applicable, economical, beautiful and harmonious with the environment” on architectural design, and conforming to correlative codes and standards, architectural plan design required in the design assignment are accomplished. Based on these, elevation, section and detail drawing are designed. The number of total architectural drawings is 5.On the principle of “safe, applicable and durable” on structural design, vertical load and horizontal load acting on the building are calculated. Internal force of structure is figured out. In addition, internal force combination and seismic check for the structure are given. Slab, beam, column, stair canopy and foundation are designed. The number of total structural drawings is2 .
Keywords: frame type mall buiding frame structure single footing
