施工组织设计作为建筑企业施工组织的纲领性文件,对实行施工活动科学管理有着重要的意义,并且具有战略部署和战术安排的双重作用。通过施工组织设计的编制,深刻体会到施工组织设计在实际施工过程中的重要性,以及如何编制施工组织设计,掌握了编制的程序、主要的内容及重点,可为施工组织设计的编制提供借鉴。 以下是土木毕设网小编为大家搜集整理的施工组织设计英文文献,供大家参考和借鉴!更多内容尽在参考文献栏目!
参考文献一
[1]Hatem Abou-Senna,Essam Radwan,Alexander Navarro,Hassan Abdelwahab. Integrating transportation systems management and operations into the project life cycle from planning to construction: A synthesis of best practices[J]. Journal of Traffic and Transportation Engineering (English Edition),2018,5(1):.
[2]Gordon Hutchins,Heike I. Grabsch. How to make tissue microarrays[J]. Diagnostic Histopathology,2018,24(4):.
[3]Watson. Learning from the Environment and Making: Using Analysis and the Senses[J]. Journal for Education in the Built Environment,2014,9(1):.
[4]K.Z. Sha'ar,S.A. Assaf,T. Bambang,M. Babsail,A.M. Abd El Fattah. Design–construction interface problems in large building construction projects[J]. International Journal of Construction Management,2017,17(3):.
[5]Nikovi? Ana,Mani? Bo?idar,Maruna Marija. Contemporary architectural practice: Institutional framework and building rules[J]. Arhitektura i Urbanizam,2015,2015(40):.
[6]Adrian Pitts. Passive House and Low Energy Buildings: Barriers and Opportunities for Future Development within UK Practice[J]. Sustainability,2017,9(2):.
[7]Gambatese John,AlOmari Kasim. Degrees of connectivity: Systems model for upstream risk assessment and mitigation.[J]. Accident; analysis and prevention,2016,93:.
[8]Matja? Panjan. Influence of substrate rotation and target arrangement on the periodicity and uniformity of layered coatings[J]. Surface & Coatings Technology,2013,235:.
[9]Kiavash Parvan,Hazhir Rahmandad,Ali Haghani. Inter-phase feedbacks in construction projects[J]. Journal of Operations Management,2015,39-40:.
[10]Yiqiang Xiang,Ying Yang. Challenge in Design and Construction of Submerged Floating Tunnel and State-of-art[J]. Procedia Engineering,2016,166:.
[11]Henny Yustisia. The Evaluation of Constructability towards Construction Safety (Case Study: Kelok-9 Bridge Project, West Sumatera)[J]. Procedia Engineering,2014,95:.
[12]Julia Stehli,Olivier F. Clerc,Tobias A. Fuchs,Mathias Possner,Christoph Gr?ni,Dominik C. Benz,Ronny R. Buechel,Philipp A. Kaufmann. Impact of monochromatic coronary computed tomography angiography from single-source dual-energy CT on coronary stenosis quantification[J]. Journal of Cardiovascular Computed Tomography,2016,10(2):.
[13]Paulo Pereira da Silva,Carlos Vieira,Isabel Vieira. The determinants of CDS open interest dynamics[J]. Journal of Financial Stability,2015,21:.
[14]Olav Torp,Alemu Moges Belay,Carl Thodesen,Ole Jonny Klakegg. Cost Development Over-time at Construction Planning Phase: Empirical Evidence from Norwegian Construction Projects[J]. Procedia Engineering,2016,145:.
[15]Rasheda Khanam. Child health and schooling achievement in Bangladesh[J]. International Journal of Social Economics,2014,41(1):.
[16]Elias P. Koumoulos,Ioannis A Kartsonakis,G Vlachakis,M Vlachakis,Costas A. Charitidis. Corrosion investigation and evaluation of mechanical and structural properties of powder coatings[J]. International Journal of Structural Integrity,2016,7(1):.
[17]Boonlert Watjatrakul. Intention to use a free voluntary service[J]. Journal of Systems and Information Technology,2013,15(2):.
[18]Lines,Sullivan,Hurtado,Savicky. Planning in Construction: Longitudinal Study of Pre-Contract Planning Model Demonstrates Reduction in Project Cost and Schedule Growth[J]. International Journal of Construction Education and Research,2015,11(1):.
[19]Phoaphan, B.,Potivejkul, S.,Chaisiri, P.,Yutthagowith, P.. Design and construction of a prototype saline solution resistive voltage divider[P]. ,2013.
[20]Wang, Haiying,Qin, Fen,Zhang, Xin Chang. The research on the construction method of urban planning virtual landscape based on Skyline[P]. ,2013.
[21]Murali, B.,Nagarani, J.. Design and fabrication of construction helmet by using hybrid composite material[P]. ,2013.
[22]Ciccozzi, F.. From models to code and back: Correct-by-construction code from UML and ALF[P]. ,2013.
[23]Zhou Xiaojun,Yang Changyu,Wang Jinghe,Yu Xueying. Study on Structural Design and Construction Procedure for a Triple Arch Railway Tunnel[P]. ,2013.
[24]Calderi?n, O.,Di?az, A.C.,Orjuela-Ca?o?n, A.D.,Lores, M.,Legra?, C.,Pe?rez, L.. Design and construction of the motor system for a gait trainer with step regulator planetary system without changing the gear pairs[P]. ,2013.
[25]Wenyu Chen,Jiayin Zhou,Wei Xiong,Weimin Huang,Thiha Oo,Venkatesh, S.K.. Planning of hepatectomy for tumor resection: Resection surface construction and optimization[P]. ,2013.
[26]Belfiore, Nicola Pio,Verotti, Matteo,Crescenzi, Rocco,Balucani, Marco. Design, optimization and construction of MEMS-based micro grippers for cell manipulation[P]. ,2013.
[27]Majewski, T.,Nunez, M.I.Q.. Design and construction of a mini-robot with terrestrial locomotion[P]. ,2013.
[28]Cocilovo, V.,Cucchiaro, A.,Cuneo, S.,Drago, G.,Gabriele, M.,Polli, G.M.,Rossi, P.,Sprecacenere, G.,Terzi, F.. Qualification process and quality control planning for JT-60-SA Toroidal Field coils construction[P]. ,2013.
[29]Rafiee, M.,Afjei, E.,Siadatan, A.. Design and construction of a new SRM sensorless driver[P]. ,2013.
[30]Sung-suk Choi,Eung-kon Kim. Design of construction stability test system using small unmanned aerial vehicle based on image processing[P]. ,2014.
[31]Ghosh, R.. Construction of plant friendly input excitations for ill-conditioned multivariable process identification[P]. ,2014.
[32]Verbeke, J.,Hulens, D.,Ramon, H.,Goedeme, T.,De Schutter, J.. The design and construction of a high endurance hexacopter suited for narrow corridors*[P]. ,2014.
[33]Kallaste, A.,Vaimann, T.,Belahcen, A.. Possible manufacturing tolerance faults in design and construction of low speed slotless permanent magnet generator[P]. ,2014.
[34]Johnson, S.,Hsu, D.,Jue Gao,Jiajin Yuan,Minjie Sian,Ye Zhou. Informatization construction of moral education curriculum resources in schools and universities[P]. ,2014.
[35]Karels, Lucas D.. Foundation design and construction challenges at river crossing for 345 kV transmission line[P]. ,2014.
[36]Dang, Jie,Mayor, J.Rhett,Semidey, S.Andrew,Harley, Ronald,Habetler, Thomas,Restrepo, Jose. Practical considerations for the design and construction of a high speed SRM with a flux-bridge rotor[P]. ,2014.
[37]Medvedev, S.N.,Aksyonov, K.A.. Comparative analysis of multi-agent systems and Kanban system in the construction of operational production plans for engineering enterprises[P]. ,2014.
[38]Quintero Salazar, E.A.,Orozco, J.M.,Henao Toro, D.F.. Design and construction of an astronomical online observatory[P]. ,2014.
[39]Siwei Zhao,Zongmin Li. Multi-objective Optimization for Construction Site Layout Planning Problem under Fuzzy Random Environment[P]. ,2014.
[40]McEvoy, M.,Komendera, E.,Correll, N.. Assembly path planning for stable robotic construction[P]. ,2014.
[41]Ford, J.,Bloss, M.,Brandt, J.,Creager, R.,Demorest, P.,Jones, G.,Jintao Luo,McCullough, R.,Prestage, R.,Ransom, S.,Ray, J.,Watts, G.,Whitehead, M.. Experiences with the design and construction of wideband spectral line and pulsar instrumentation with CASPER hardware and software: The Digital Backend System[P]. ,2014.
[42]Merschbrock, C.,Munkvold, B.E.. Succeeding with Building Information Modeling: A Case Study of BIM Diffusion in a Healthcare Construction Project[P]. ,2014.
[43]Branco da Silva, P.R.,Silva, D.. Design of lattice network codes based on Construction D[P]. ,2014.
[44]Xi Chen,Crossley, P.A.,Hao Guo. Design, construction and validation of a next generation protection and control system based on IEC61850 standards[P]. ,2014.
[45]Alam, K.,Ray, T.,Anavatti, S.G.. Practical application of an evolutionary algorithm for the design and construction of a six-inch submarine[P]. ,2014.
[46]Rahman, M.M.,Carmenate, T.,Bobadilla, L.,Mostafavi, A.. Ex-ante assessment of struck-by safety hazards in construction projects: A motion-planning approach[P]. ,2014.
[47]Salon, S.,Ergene, L.T.. Design and construction of a low-vibration low-leakage field motor[P]. ,2014.
[48]Jamali, Babak,Otal, Shawn,Ma, Byron,Mogilevsky, Alex. Risks in design, construction and testing of grounding system: A recent CEATI project by GLTF (Grounding and Lightning Task Force)[P]. ,2014.
[49]Barros dos Santos, S.R.,Nascimento Junior, C.L.,Givigi, S.N.. Planning and learning for cooperative construction task with quadrotors[P]. ,2014.
[50]Zhang Bin,Li Ruijun,Zhang Jing,Zhao Wei,Tang Lijian. Fundamental measures of the complex SoS capability oriented to the planning and decision-making of engineering construction[P]. ,2014.
参考文献二
[1]徐永秋. 建筑工程中施工组织设计优化及成本控制研究[J]. 居舍,2018,(29):90.
[2]何俊兰. 项目投标阶段施工组织设计的编制[J]. 农业科技与信息,2018,(16):83-84.
[3]汤乐. 优化施工组织设计降低工程造价[J]. 南方农机,2018,49(03):199+202.
[4]沈川. 浅议建筑工程施工组织设计及施工工艺[J]. 中国新技术新产品,2017,(24):108-109.
[5]熊群英. 施工组织设计课程教学改革探索——多维立体化教学视角[J]. 中国教育学刊,2017,(S1):140-142.
[6]张晓颖. 土右电厂空冷机组工程施工组织设计方案优化研究[D].华北电力大学,2017.
[7]史慧. 施工组织设计对钢结构工程项目成本的影响研究[D].郑州大学,2016.
[8]李洁. 施工组织设计优化对降低施工成本的影响研究[D].南昌大学,2016.
[9]金鑫. 某复建工程施工组织优化设计[D].湖南科技大学,2016.
[10]董俊鹏. 优化施工组织设计降低工程造价[J]. 居业,2016,(04):160+162.
[11]郭志强,刘永新,李红利. 神华铁路隧道机械化清筛施工组织设计方案研究[J]. 神华科技,2016,14(02):82-85.
[12]黄志怀,范小叶. 市政企业施工组织设计的分类管理[J]. 市政技术,2016,34(01):182-184.
[13]林孟洁. 建筑施工组织设计在工程中的重要性管窥[J]. 四川水泥,2015,(11):122.
[14]王国强. 基于BIM的承包商成本管理研究[D].中国矿业大学,2015.
[15]王利锋. 前坪大桥项目施工组织设计与施工管理研究[D].燕山大学,2015.
[16]李磊. 施工组织设计对高层建筑的全方位控制[J]. 四川水泥,2015,(04):161.
[17]王卫. 建筑施工组织设计的优化与管理[J]. 黑龙江科学,2014,5(08):27.
[18]马彦刚. 浅谈单位工程施工组织设计的重要性[J]. 科技展望,2014,(11):46.
[19]毛庆虎. 浅析公路桥梁施工组织设计和施工管理[J]. 中国高新技术企业,2014,(08):101-102.
[20]周秀云. 优化施工组织设计降低工程造价[J]. 福建建材,2014,(02):113-114.
[21]付尚波. 浅析园林绿化工程的施工组织设计[J]. 绿色科技,2013,(06):134-135.
[22]王小龙. 公路桥梁施工组织设计和施工管理初探[J]. 科技与企业,2013,(11):32.
[23]庞浩. 特高压直流输电线路工程施工组织设计方案优化研究[D].华北电力大学,2013.
[24]王力. 论建筑工程施工组织设计的优化[J]. 科技创业家,2013,(09):35.
[25]赵宏坤. 洪火线五凤头桥改建工程施工组织设计研究[J]. 内蒙古公路与运输,2013,(01):38-39.
[26]金红华. 浅谈施工组织设计编制问题及改进措施[J]. 城市建筑,2013,(04):240+244.
[27]刘东明. 建筑工程施工组织设计的重要性及其发展与创新[J]. 科技与企业,2013,(04):66.
[28]孟于恒. 成都至都江堰铁路彭州支线工程施工组织设计[D].西南交通大学,2013.
[29]石华堂,唐明,廖荣斌. 基于灰色层次分析法的施工组织方案比选[J]. 公路工程,2012,37(06):161-165+184.
[30]张晓宇,张凯. 建筑施工组织与设计[J]. 河南建材,2012,(05):113-114.
[31]杨东生. 施工组织设计对公路施工成本影响与优化研究[D].天津大学,2012.
[32]段晓波. 电力工程施工组织设计及其优化研究[J]. 科技资讯,2012,(23):157-158.
[33]孙玉兰,王福林,李先明,朱海城. 哈大铁路客运专线指导性施工组织设计与项目管理[J]. 铁道标准设计,2012,(05):30-32+36.
[34]余爱华,王大明. 《施工组织设计》课程建设的研究与实践[J]. 森林工程,2012,28(03):85-87+90.
[35]郑习羿. 山区铁路施工组织设计探讨[J]. 铁路工程造价管理,2012,27(01):15-17+31.
[36]王树杰,杨新安,张业炜,凌保林. 铁路施工组织优化设计系统研究与开发[J]. 华东交通大学学报,2011,28(04):47-51.
[37]兰鸣. 建设工程施工组织设计优化研究[D].北京林业大学,2010.
[38]苏长革. 对当前公路工程施工组织设计的思考[J]. 市场论坛,2008,(09):71-72.
[39]刘娟. 浅谈施工组织设计的发展[J]. 科技创新导报,2008,(02):176.
[40]陈金平. 浅谈园林种植工程的施工组织设计[J]. 南方农业(园林花卉版),2007,(06):50-51.
[41]魏霆. 优化施工组织设计 合理确定工程造价[J]. 山西水利科技,2007,(04):82-83.
[42]孙维波. 浅议施工组织设计与责任成本管理[J]. 山西建筑,2007,(26):277-278.
[43]高印章,顾艳红. 水利水电工程施工组织设计编制[J]. 四川水力发电,2006,(03):113-116.
[44]徐春,刘天波. 高层建筑施工组织设计编制探讨[J]. 国外建材科技,2004,(01):125-127.
[45]胡明珠. 工程施工组织设计与施工管理[J]. 公路与汽运,2002,(01):59-60.
[46]王龙,袁牧,余新明,盖暹东. 投标前后施工组织设计的比较[J]. 建筑技术,2001,(04):266-267.
[47]李卫平. 优化施工组织设计 降低桥梁工程造价[J]. 铁路工程造价管理,2000,(05):21-22.
[48]甘文喜. 加强施工组织设计 降低水电工程造价[J]. 水力发电,2000,(07):36-38.
[49]周国恩. 高层建筑施工组织设计编制问题的探讨[J]. 广西工学院学报,1998,(01):37-41.
[50]杨宝珠. 实施“施工组织设计”的分析与研究[J]. 天津城市建设学院学报,1997,(02):19-22.
