此设计为圣都小学教学楼结构设计,该建筑物主体结构3层,总长度是60.8米,总宽度是11.5米,总高度是12.3米。
内力计算考虑以下四种荷载作用,即竖向恒载、活载作用下的内力,风载作用下的内力以及水平地震荷载作用下的内力。
设计分为建筑设计部分、结构设计部分、基础设计部分;建筑设计严格按照相关规范规定设计,采用CAD作图软件进行平面、立面以及剖面设计;在结构设计时,取一榀框架计算;采用PKPM出梁、柱、板及基础施工图,基础部分设计时采用柱下独立基。
设计包括的内容有梁柱设计、屋面板设计、楼面板设计以及基础和楼梯设计,通过对这些结构的设计,可以了解并掌握整个建筑结构设计的全过程。
关键词:结构设计; 框架;抗震设计
This is the teaching building structural design for ShengDu primary school, the main structure of this building has three layers,with a total length of 60.8 (sixty point eight) meters, a total width of 11.5 meters, and the total height of 12.3 meters.
When calculating the internal force, we should consider the following four kinds of load effects such as: internal force under the action of the vertical dead load and live load, the internal force under the action of wind load and internal force under earthquake load.
This design includes the architectural design, the structural design, and the basic design.the architectural design is in accordance with the relevant regulations.using CAD drawing software to design the plane, elevation and profile;in structural design, calculating a frame of a roof truss, adopting PKPM to make the beam, column, plate and foundation construction drawing, using the single foundation under column when design the basic part.
The design includes the following contents of beam and column design, roof boarding and floorboard design, foundation design and stair design. We can understand and master the whole process of the design of the whole building structure.through these structural designs.
Key words: The framework;The structure design ;Seismic design
建筑面积:5000m2
建筑层数:3层
建筑高度:12.3m
计算书.pdf
(865.8 KB, 下载次数: 3)
